lights on all the time
i have a problem with the front and rear lights, they stay on all the time as if they were switched to the 1 st on postion on the stalk ( side lights) also the heater blower is doing similar things when switched off it still run's as if switched to the no1 postion not sure if related.
I used to have twin headlights but now back to standard but they have always been the same and i want to get it sorted out any idea's thanks
the blower when in the o position of the o,1,11,111 switch is not actually off, its low, you need to turn the 0,^,¬ knob to o aswell
sidelights.. it may have a link in the fusebox that actually bypasses teh column switch - scandinavian cars had this done, of the top of my head i cant remember which link it is though... as long as they go off when the ignition is off - that wouldnt bother me - as it stops the common problem of the faulty sidelight switch failin on the stalk
steerfromdarear
28
Jan 29, 2016 06:14 PM
borboyous
Aug 22, 2015 11:17 AM
