Boost
Old Dec 4, 2003 | 12:39 PM
JamesH's Avatar
JamesH
Default Boost
Hi guys,
I have recently accuired a 2WD saff cosworth and I have got 328BHP at 21PSI.
What I want to know how do i turn up the boost to 26PSI?
I have been told that by doing so I can get 353 BHP
I want to do this exact and properly but don't really want to get it r/r cos it was recently done.
Thanks chaps I know its got something to do with the actuator [/flash]
Old Dec 5, 2003 | 06:04 PM
big_wig_074's Avatar
big_wig_074
right,disclaimer here:i aint responsible for blowing your engine!!!
if you take the rod end off the turbo(split pin,circlip,whatever holds it on, off and pull it up!) then wind the rod clockwise up the shaft to shorten it.try 2 half turns then check the boost(dont just leather it up the road!go about 50mph in 3rd then lightly apply the brakes to put the engine under load,hence the boost will increase,you can then check the peak without goin 120mph!!!dont do this for too long for your brakes sake!then adjust as necessary by repeating the first step if too low or winding out if too high!simple fella.)
Old Dec 6, 2003 | 11:42 AM
JamesH's Avatar
JamesH
Cheers mate!
Is it quite poss I'll blow the engine then?
Old Dec 6, 2003 | 05:20 PM
big_wig_074
yup,guaranteed if you go "oooh i wonder whatll happen if i just tweek it a LITTLE more"keep doin it,bleed valve stylee then BOOM!!!!!!!!
Old Dec 6, 2003 | 08:18 PM
JamesH's Avatar
JamesH
LOL Nah I aint like that mate
Old Dec 7, 2003 | 01:30 PM
big_wig_074
good good!have fun mate!
Old Dec 8, 2003 | 10:23 AM
JamesH's Avatar
JamesH
Cheers will do
Old Dec 8, 2003 | 10:41 AM
Toe Knee's Avatar
Toe Knee
Alternatively take it to a tuners and get it set up properly!!! are u 100% sure the chip u got can handle that boost and wont lean out?!?! only way ur gonna know 100% for sure is get it done properly or end up melting something trust me i know
Old Dec 8, 2003 | 02:57 PM
JamesH's Avatar
JamesH
I was playing with the idea haven't had it long will get it r/r one day soon
Not really concerned about running more boost just wanted to know how really
Old Dec 16, 2003 | 11:57 AM
Guinnless's Avatar
Guinnless
WARNING
Unless you know exactly what you are doing then 26PSI may result in 0BHP.
Can you tell us whose chip and what injectors. What exhaust housing are you using?
Old Dec 16, 2003 | 12:37 PM
JamesH's Avatar
JamesH
I have-a no clue
Thanks for the concern matey
Am gonna wait till the next time it gets rolling roaded
Old Dec 16, 2003 | 12:41 PM
JamesH's Avatar
JamesH
Green injectors
Old Dec 16, 2003 | 03:06 PM
Guinnless's Avatar
Guinnless
I run a max of 24psi held on green injectors on a Bayjoo chip. Any more boost really needs a live map to be safe.
Also if you have different cams then 21psi may be the max you can go to.
Stay safe.
Old Dec 16, 2003 | 05:32 PM
JamesH's Avatar
JamesH
Cheers mate, will do
bloke
Old Jan 6, 2004 | 12:52 PM
cossiesfx's Avatar
cossiesfx
mine is stage 3 t34 48 housing dark greens and i have it holding 24 peaking 26 was told this keeps it fast and stops it from blowing up............
24 is plenty!!!
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
