battery warning light???
Old Jan 27, 2006 | 03:40 PM
CraigJ's Avatar
CraigJ
Default battery warning light???
in my cabby is starting to bug me when using my leccy windows or sumtimes when braking it comes on ive had the car bout 4 months and its been doing all the time but the battery is charging fine. any ideas???
Old Jan 27, 2006 | 04:42 PM
Wazzzer's Avatar
Wazzzer
the motors could be pulling too much power off the batt cos they're knackered...
Old Jan 27, 2006 | 09:28 PM
wing's Avatar
wing
sounds like a bad earth
Old Jan 28, 2006 | 07:44 PM
andyt's Avatar
andyt
my old series 1 use to do it mate, and it got brighter as i braked aswell dont worry about it
Old Jan 28, 2006 | 07:46 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Take the bulb out
Old Jan 28, 2006 | 08:03 PM
Combi_Chris's Avatar
Combi_Chris
the earth cable from the alt to batt is so small on the mk 4 , ive changed mine and all the earth straps , other than that id say alt is weak, or battery is old and tired , it certainly shouldnt be doing it though , get your batt checked 1st
Old Feb 13, 2006 | 11:11 PM
paconassa's Avatar
paconassa
How do "PROPERLY" (lol) test a batery??????
Old Feb 14, 2006 | 01:10 PM
SafeChav's Avatar
SafeChav
Originally Posted by Tony Turbo
Take the bulb out
Never thought i'd hear u say that
My guess.........your brushes are going on your alternator.....and when you use high power items on the car the alternator can't keep up and stops charging momentarily. The battery light derives its earth from the alternator, and can only be earth when not charging..........
Old Feb 14, 2006 | 01:11 PM
SafeChav's Avatar
SafeChav
Thats an easy one, u get two wires from each terminal, stick your tongue out, and i think the rest is fairly self-explanitory
Old Feb 15, 2006 | 05:52 PM
Glen's Avatar
Glen
chances are the ignition feed to the battery light is sh*t. If the light only comes on dim this is the prob, fixed loads like that. Just run a new ignition feed to the bulb !!!!!!!!!!!!!!!!!!!!!!!!!!
Old Feb 15, 2006 | 06:01 PM
SafeChav's Avatar
SafeChav
If the alternator is charging there is no earth for the bulb so there isn't really anyway it can illuminate?
Old Feb 15, 2006 | 08:21 PM
Glen's Avatar
Glen
If the igntion feed has a low voltage, and the alternator is charging and sending a good feed 12v upto 14.4 then the resistance from the ignition feed can cause the bulb to "glow" dim. Caused when ignition circuits from the same supply draw current and the feed to the bulb drops to a lower voltage. Up the ign supply and it'll fix the prob for sure, I have done this on several escorts and it has worked every time. I just soldered a feed from the ign on the barrell (heavy black wire) and ran it to the ignition feed at the back of the intruments multi plug (black wire again i beleive) !!!
Old Feb 15, 2006 | 08:54 PM
SafeChav's Avatar
SafeChav
Ah yeah i get you, that would have to be a fairly high resistance though???? That car in my siggy did that come to think of it, driving at night u could barely see it glowing only when you were somewhere very dark.
Just out of interest, obviously you have the cure for that fault, but what causes the fault? That would have to be wiring breaking down or something?
BUT anyway.....do u think this could be the cause of the light coming on.....? I wouldnt of thought so myself?
Flatlinedan
Sep 18, 2015 12:41 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
fuzzy
Sep 4, 2015 10:11 PM
