rs turbo brakes
i have a rst cabby it has drilled a groved disks but there getting warped now. im running bout 180-200 bhp wot are the best disks/pads to go for or do u guys think im better off upgrading to coswoth stuff if so wot parts do i need to get? is there any custom parts i need to get?
Originally Posted by addiction
get some 2wd cossie disks and adaptor brackets to raise the calipers up!
Ben
no they dont effect the offset. all you have to is tap a 12mm thread in the top hole on the hub! piece of piss to fit!
http://www.randbmotorsport.co.uk
look under the brakes section
Originally Posted by BillyCabrio
Or an even better combo is the 2wd discs with the 4x4 callipers.......
All bolts straight on
They are easier because yeah, they go straight on, but using RST calipers have a bigger braking surface area
o right yer , i think then i will use my original calipers and the 2 wd disks
Does it matter then if i have xr3i calipers on my cab because it was a xr3i originaly
are the xr3i and rst calipers the same ??
Ben
Ben
It is something you can always add later...
Has the car got ABS? If so, rip that crap out and the brakes will be loads better anyway.
I am quickly running out of helpful replies. Soon I will have to go back to making silly sarcastic replies like I usually do. I have been faaaar too helpful this morning. I must have got up out of the right side of the bed
Ben
Now theres something i never knew!
I dont understand how they have a bigger braking surface tho
The calipers are the same size and take the same pads, but the piston on an RST is bigger.
Where do you get ya information from? lolI swear blind the cossie calliper was bigger
Oh well lol, too late now
From messing with RST's for the last 5 years lol
I said the RST piston was bigger than an XR3i one, not a Cosworth caliper
It's something to do with the angle. Can't remember now exactly. YEARS ago there was a section on the turbosport site that Clint wrote comparing various brake options for an RST. It showed that using RST calipers with 2wd discs gave a better braking percentage than using 4x4 calipers and 2wd discs.
As the cossie pads are far bigger than the RsT stuff
So the RST piston is bigger that a 4x4 piston?
Originally Posted by s1_turbo
What pads would you use for the 2wd discs, RST ones or 2wd ones? And what are the best? Cheers
If you are using RST calipers, then you use an RST pad. If you are using 2wd calipers, then you use 2wd pads...
s1_turbo
I got mine from Mike Rainbird in Norwich.............. Who it turns out orders them from Hi-Spec in Dartford up the road from me
Matt Baxter
Sep 16, 2015 08:30 PM
Ben26
Aug 27, 2015 08:56 PM
Red_bull
Aug 9, 2015 08:34 AM
[/quote]
