escos geometry
Old Jan 25, 2006 | 11:02 AM
trotty's Avatar
trotty
Default escos geometry
hi all,
i'm going to get a 4 wheel allignment done at the weekend after having new track control arms fitted and new suspension springs.
i was wondering if someone can tell me what the ideal set up is for when i go to get it done?
any help appreciated.
Old Jan 25, 2006 | 02:14 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
How does the car get driven?
1. Mainly motorways?
2. Mainly twisty back roads?
3. Lots of track days?
Old Jan 25, 2006 | 03:40 PM
trotty's Avatar
trotty
ah good point!
mainly twisty country lanes, and some faster a roads.
i maybe thinking about the odd track day too.
cheers.
Old Jan 26, 2006 | 11:18 AM
Mike Rainbird
Caraholic
Unless you have a Grp A rear beam or "slot" the mounting points, the rear is not adjustable. 1.5° negative camber all round and 0'20s toe-in.
Most places will try and get you to run the toe parrallel, as this is what Ford recommends. However, this doesn't tak into account the bush deflection you get with forward movement, so if you set it to parrallel when the car is static, it will toe-out on the move causing the inside edges of the tyres to wear. If you set to toe-in slightly when it is static, you will get parrallel then when the bushes deflect in forward motion. A bit of toe-in gives the car some stability anyway... .
Old Jan 26, 2006 | 11:31 AM
trotty's Avatar
trotty
thanks for that mike!
by the way, those bayjoo springs you sold me are so much better than the previous ones i had! feels really good now so thanks again mate.
Old Jan 26, 2006 | 12:16 PM
Azrael's Avatar
Azrael
You think this slotting is sensible?
I was to get Zoo beam but aparently that is going to be delayed due to things happening... My rear geometry is way wrong :-/ One wheel +0,01 one -0,10
Old Jan 26, 2006 | 12:28 PM
Dave Henshall's Avatar
Dave Henshall
so like on my setup - completely std dampers & springs but fully poly bushed on 18's - insist on having the front toeing in 20 minutes when static ? ( as above, - mainly for back lane raggin)
Old Jan 26, 2006 | 01:46 PM
Mike Rainbird
Caraholic
If it's good enough for the Grp N boys then yes. However, once the desired settings have been reached, the holes need to be "tacked" to prevent any movement.
Your settings would suggest to me that you have a bent rear beam. The standard item is not particularly strong and given your descriptions of the Polish roads, not surprising .
Old Jan 26, 2006 | 05:38 PM
Azrael's Avatar
Azrael
Tacked? I heard about welding them back.
Well I changed it for a new one some km's ago but was always a little bit wrong. Still was better when the car was lower, when I raised it it got wrong. I was to change for adjustable beam anyway but it's not so easy to get a beam from UK here for reasonable money, also now it would be hard to get Zoo Beam.. is there any other make?
Old Jan 26, 2006 | 06:35 PM
Dave Henshall
cos im lazy
can someone covert 20 minutes of toe in angle to mm on teh escos wheelbase please so i can get selectatyre to do mine as soon as its all back together
Old Jan 26, 2006 | 10:22 PM
dave cos4x4's Avatar
dave cos4x4
Mike,
does your settings go with fully a polybushed front end.
can you give me the ideal settings for fast road/track.
need work doing to mine and will have to get it all set up when done.
thanks.
Old Jan 27, 2006 | 07:36 AM
Mike Rainbird
Caraholic
Dave,
That is correct. To save me typing it all out again, m
My suspension settings are all here: https://passionford.com/forum/viewto...128432&start=0
Old Jan 27, 2006 | 07:48 AM
MONSTER's Avatar
MONSTER
Originally Posted by Dave Henshall
cos im lazy
can someone covert 20 minutes of toe in angle to mm on the escos wheelbase please so i can get selectatyre to do mine as soon as its all back together
Does this mean you're keeping it now Dave?
Old Jan 27, 2006 | 08:01 AM
Dave Henshall
oh yes - gonna get 2 new fronty tyres and have it tracked up prperly aswell
my tyre centre doesnt measure teh toe in degrees minutes and seconds, but in mm, so i need the length of teh wheelbase and then convert 20 minutes into actual mm for their laser tracker....
Old Jan 27, 2006 | 08:22 AM
MONSTER's Avatar
MONSTER
Good man
You mamage to sort an engine or are you having yours fixed?
Old Jan 27, 2006 | 09:53 AM
Dave Henshall
fixed
Old Jan 27, 2006 | 02:07 PM
Azrael's Avatar
Azrael
my tyre centre doesnt measure the toe in degrees minutes and seconds, but in mm, so i need the length of the wheelbase and then convert 20 minutes into actual mm for their laser tracker....
IF it;s modern laser thing I'm 99% sure it can be switched to degrees.
Old Jan 27, 2006 | 02:12 PM
Dave Henshall
its not that new though, theyve had it years -
what would it be roughly, 0.5mm toe in on each front wheel?
Old Jan 27, 2006 | 02:16 PM
Azrael's Avatar
Azrael
Maybe Mike will disagree but what you want is only slightest of the slight toe-in. Slight toe-out will under load will help it turn but make it much more unstable. Excessive toe-is will make it hard to make it turn.
Old Jan 27, 2006 | 02:20 PM
Dave Henshall
it feels quite unstabe at high speed, but quite sharp at low speed -
Old Jan 27, 2006 | 02:28 PM
Azrael's Avatar
Azrael
May be a bit too much toe-out under load then. BUt this maybe some of inherent characteristics of the car. Like relatively low castror angle wich makes it a little bit nerous but much sharper.
Old Jan 27, 2006 | 02:29 PM
Dave Henshall
but if its been set dead parallel - under load, it will toe out - thus causing it to hunt and tramline, its a good point mike has made obout the deflection of teh bushes - not though of that before
Old Jan 27, 2006 | 05:43 PM
dave cos4x4
Dave,
thanks Mike.
Old Jan 27, 2006 | 10:32 PM
Azrael's Avatar
Azrael
but if its been set dead parallel - under load, it will toe out - thus causing it to hunt and tramline, its a good point mike has made obout the deflection of the bushes - not though of that before
It is, although I always set it nearly 0 and just got used to it being a little bit tricky. I don't like the feeling of car that is set to toe-in in tight corners it understeers in a way I really dislike.
Old Jan 28, 2006 | 09:21 AM
Dave Henshall
hmmm,
suppose i will just have to try it - its only 30 quid to have to ajusted
Old Jan 28, 2006 | 09:22 AM
Azrael's Avatar
Azrael
If it's only...
Cheaper over here
Old Mar 23, 2006 | 02:30 PM
Dave Henshall
bttt for mike
if i wanted it to be dead stable and not wear tyres on long motorway hauls,, what would you recommend for the toe in/out at the front end as opposed to slightly toeing in for normal fast road /back lane stuff?
Old Mar 23, 2006 | 02:51 PM
Azrael's Avatar
Azrael
Probably even more toe-in depending on the flexibility of bushes you run.. So that while cruising it's parallel
Old Mar 23, 2006 | 03:34 PM
Mike Rainbird
Caraholic
The settings I have on my car give 100% even wear apart from on track where the outside edges wear due to cornering forces.
Old Mar 23, 2006 | 03:42 PM
Dave Henshall
thats all i need to know
currently mine wear on the inside edges, only on the front 2 though..
Old Mar 23, 2006 | 03:44 PM
Azrael's Avatar
Azrael
What camber you run?
Old Mar 23, 2006 | 03:49 PM
Dave Henshall
std, its all std apart from poly bushed thoughout suspension wise
and the wear is due to one of the wheels being the wrong offset so it turns out and they ajusted the tracking (what they thought) was parallel
Old Mar 23, 2006 | 03:51 PM
Azrael's Avatar
Azrael
OH I see... managed to get right wheel?
Old Mar 23, 2006 | 03:58 PM
Dave Henshall
yep, gonna swap them all round and have the odd one with the best of the old tyres as a full size spare
Old Mar 23, 2006 | 04:13 PM
Azrael's Avatar
Azrael
You carry full size spare? You don't have much boot space, do you?
gcfcos
59
Oct 6, 2015 05:04 PM
landaqmabba
Sep 15, 2015 07:16 PM
gcfcos
Sep 11, 2015 06:03 PM
Mickeystewart
Sep 9, 2015 04:04 PM
