S2 idle when cold
Old Jan 24, 2006 | 10:33 AM
Hrsturbo's Avatar
Hrsturbo
Default S2 idle when cold
When cold my S2 sounds like its only firing on 3 cylinders. As soon as its driven 3 meters it runs perfect until the next morning when it does it again!
How can I sort this??
thanks
Old Jan 25, 2006 | 11:11 AM
Hrsturbo's Avatar
Hrsturbo
Old Jan 25, 2006 | 09:36 PM
antony215's Avatar
antony215
Escort Rs Turbo
Get a new coldstart valve
Old Jan 26, 2006 | 10:04 AM
Rick's Avatar
Rick
she's a tad lean or rich mate. dont worry about it.
Old Jan 26, 2006 | 01:47 PM
LEE-RS's Avatar
LEE-RS
Custom
test your heated seat fuse mate as it controls the black fuel ecu and coldstart valve
Old Jan 26, 2006 | 03:06 PM
Hrsturbo's Avatar
Hrsturbo
Heated seat fuse??? I got an H reg escort rs turbo , wish it had heated seats though
If its a tad rich or lean I want to worry How does it make it do this?
My cold start injector isn't connected any more so is the valve doing something else?
Thanks for replies, hopefully will get to the problem very soon
Old Jan 26, 2006 | 03:12 PM
LEE-RS's Avatar
LEE-RS
Custom
i know they have not got heated seats thats why ford put the fuse there for the black fuel ecu it will not run right without it as it controls the fueling
Old Jan 26, 2006 | 03:18 PM
Hrsturbo's Avatar
Hrsturbo
right will check it now see if its gone or not
Old Jan 26, 2006 | 03:42 PM
LEE-RS's Avatar
LEE-RS
Custom
as posted by Stu @ M Developments
Briefly:
The KE Jetronic system has ELECTRONIC enrichment via the black box.
This enrichment box is responsible for:
Choke:
Additional fuel when cold to make her start.
Part load accel:
Additional fuel when accelerating.
Full Load Accel:
This is the important one. This ecu is responsible for increasing the differential pressure in the metering head and thus givig you the extra fuel for the boost.
Fuse:
The ERST has a different wiring harness to the normal escorts and the heated seats fuse is in fact the engine management fuse on an RST loom. Sadly, Ford didnt ever bother making a new lid for the box to illustrate this fact
Old Jan 27, 2006 | 12:36 AM
rs_daz's Avatar
rs_daz
I int got no fuse in for that and mine runs like a dream..
But change ur plugs mate mine did the same till i changed them.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
A.t.p
Oct 23, 2015 07:54 PM
fordrallycar
Sep 30, 2015 07:57 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
