What is the benefit of having a trimmed compressor wheel?
Old Jan 20, 2006 | 11:16 AM
davidnormanuk's Avatar
davidnormanuk
Default What is the benefit of having a trimmed compressor wheel?
I have a stage 2 turbo and am wanting it to be less laggy. Obviously with it being a bigger Turbo it will be more laggy than the original but is thee any way of reducing this its driving me crackers. I am also getting pinking when running above 15psi so I want to get it rolling roaded and increase the fuelling slightly but I want to get any other bits I need done first so I don;t have to keep shelling out on getting it setup.
Dave
Old Jan 20, 2006 | 06:15 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
If it is detting over 15psi then turn it down!
Old Jan 20, 2006 | 06:18 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
You really sure its that laggy? Or has someone just told you that it is? An S2 with a Stage 2 Turbo isnt very laggy. Maybe there is something wrong.
Who has been setting it up?
Old Jan 20, 2006 | 10:40 PM
Combi_Chris's Avatar
Combi_Chris
whats the best unit to use OTHER than a t28 on rst engines for minimal lag ? ?
Old Jan 21, 2006 | 01:29 AM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
minimal lag= T34, Maram shaft and ALS
Old Jan 21, 2006 | 06:58 AM
Rick's Avatar
Rick
as Christian, shouldnt be laggy!
Old Jan 21, 2006 | 01:14 PM
Combi_Chris
ok so whats als ? ?
Old Jan 21, 2006 | 04:47 PM
scortgti's Avatar
scortgti
anti-lag system?? i think anyway
Old Jan 21, 2006 | 06:35 PM
MJC's Avatar
MJC
Its more likely to be a problem with how the car is setup mate! Timing on the CVH engine is critical so its probaly down to this not being set quite right and fueling. Take it to a recommended tuner and go from there.
Old Jan 21, 2006 | 07:40 PM
davidnormanuk
I've turned the boost down to stop the detonation as soon as it started to do it to stop me melting my engine bin there done that
Gonna take the car to motorsport developments to get it set up right.
It is really laggy compared to standard and the car doesn't seem to take off until you hit over 10psi. Could the compressor wheel not be matched correctly. The intake is off a 4x4 cosworth with cosworth compressor wheel?
Old Jan 23, 2006 | 08:32 PM
MJC's Avatar
MJC
Dont know the answer to any of those Q's fella but Stu at Motorsport Developments will sort you out. Thats where I took mine and was very happy with the service!
DHMC
Ford Fiesta
Sep 20, 2015 06:47 PM
Fudgey
Sep 17, 2015 01:06 PM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
