Suspension Settings?
Old Jul 19, 2004 | 05:23 PM
Milko Pete's Avatar
Milko Pete
Default Suspension Settings?
Ever since fitting coilovers to the Esc Cos, its never felt as sure footed as when on the standard setup, whats generally considered the best stiffnesses to run front and rear, ie full stiff at front half at rear etc?
Also have tried to copy the slight nose down stance that the Esc cos has standard, am I on the right track?
I realise a proffesional setup would be best but it aint an option at the mo!
Cheers.
Old Jul 19, 2004 | 05:47 PM
markk's Avatar
markk
what coil overs ? what damper ratings / what spring lengths and ratings ??
Old Jul 19, 2004 | 05:51 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
my bros are 350lb fronts and 250lbs rear but they was orderd as that from gaz so they are dapmped to match and they are 10" front and 12" rears
Old Jul 19, 2004 | 07:02 PM
Milko Pete's Avatar
Milko Pete
Fook knows, standard GAZ coilover setup!?
Old Jul 20, 2004 | 10:00 AM
Milko Pete's Avatar
Milko Pete
nico12
Dec 31, 2015 04:42 PM
turbotrev
14
Sep 27, 2015 10:44 AM
truffleshuffle
Sep 10, 2015 09:35 PM
3doorcozmess
Sep 7, 2015 01:32 PM
turbowag
Sep 3, 2015 08:07 AM
