Turbo technics say i must have a D/V, ideas please?
Old Jan 19, 2006 | 04:58 PM
AJC's Avatar
AJC
Default Turbo technics say i must have a D/V, ideas please?
turbo went today, they said over the phone that i must run a dump valve,
i prefer chatter but understanderbly i would rather have dump valve then
rather go throught the rigmorole of changing a turbo every 3 months,
does any one sell dump valves that are quiet or recirculate as i prefer chatter
cheers troops
Old Jan 19, 2006 | 05:16 PM
RST Ski's Avatar
RST Ski
yep bailey do recirculating dump valves. do you run efi?
Old Jan 19, 2006 | 05:23 PM
AJC's Avatar
AJC
no standard mfi, K.E runs lot better with out a D/V
Old Jan 19, 2006 | 05:28 PM
RST Ski's Avatar
RST Ski
i want to remove my dump valve, would i get chatter on standard boost? on mfi?
Old Jan 19, 2006 | 05:30 PM
RST Ski's Avatar
RST Ski
wont a recirculating dump valve get rid of the chatter? cos chatter is back pressure on the compessor wheel? so and recirculating valve will not put it to atmosphere but put it bk into circulation rather than allowing bk pressure?
Old Jan 19, 2006 | 05:36 PM
AJC's Avatar
AJC
you require efi for chatter
Old Jan 19, 2006 | 05:40 PM
MikeyXR2i's Avatar
MikeyXR2i
Yo Andy, yup u defo need a dump valve as you are running very high boost.
Old Jan 19, 2006 | 05:41 PM
andyt's Avatar
andyt
Andy i hate dump valves and was gonna take mine off my s1 its a 1.9 with all the trimmings and a stage 2 hybrid but after reading this im just going to leave it on mate.
I think its worth loosing the chatter and putting a DV on if its gonna stop blowing your turbo
Old Jan 19, 2006 | 05:48 PM
RST Ski's Avatar
RST Ski
how do you get chatter?
Old Jan 19, 2006 | 05:52 PM
addiction's Avatar
addiction
i dont have EFI and i get "chatter"(compressor stall to be precise!)
Old Jan 19, 2006 | 06:12 PM
RST Ski's Avatar
RST Ski
thats wot i want lol is chatter n compressor stall different sounds then?
Old Jan 19, 2006 | 06:15 PM
addiction's Avatar
addiction
granted it's not as loud as you get with efi, but it's still loud enough to make people turn and look!!
Old Jan 19, 2006 | 06:16 PM
RST_mark's Avatar
RST_mark
I'm running 14psi on a 2.0 zvh, i've just removed the dumpvalve is this gonna cause any damage to my turbo over time? If it is then i will refit it, but would rather not.
Cheers, Mark
Old Jan 19, 2006 | 06:18 PM
addiction's Avatar
addiction
leave the bugger off if your only running 14psi dude!! in boost terms 14 is not a lot
Old Jan 19, 2006 | 06:25 PM
RST Ski's Avatar
RST Ski
will i get much noise from 11.6psi 0.8bar? without a dumpvalve?
Old Jan 19, 2006 | 06:26 PM
addiction's Avatar
addiction
doubt it very much mate
Old Jan 19, 2006 | 06:31 PM
ballin's Avatar
ballin
no lol
Old Jan 19, 2006 | 06:34 PM
Leggetts 4x4 Cossie's Avatar
Leggetts 4x4 Cossie
Im running 16psi, with chatter (on full load) other then that D/V or not its personal taste.
Old Jan 19, 2006 | 06:39 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
What?!
PMSL
What turbo do you have? Need a dump valve
None of my mates use a dump valve on their cars and they don't chew up turbo's like they are going out of fashion. Mr C runs 28psi held on a GT turbo and has no trouble.
Old Jan 19, 2006 | 07:00 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
yeah agree with tony, sounds like complete rubbish needing a DV unless running silly high boost. Especially on MFI....
leave the DV off IMO.
Old Jan 19, 2006 | 07:40 PM
Rick's Avatar
Rick
Originally Posted by Tony Turbo
What?!
PMSL
To be honest mate, it's not rubbish. It's all about minimising risks and mechanical sympathy.
Old Jan 19, 2006 | 07:45 PM
adamS2RST's Avatar
adamS2RST
Serious? I mean I thought legend had it that T4 and above needed a d/v, I know this is RST terms...but surely u don't need a d/v....tbh how many turbo's is this you have gone through now in x amount of months? Doesn't sound right....
Old Jan 19, 2006 | 08:22 PM
Tony Turbo's Avatar
Tony Turbo
What?!
PMSL
But c'mon, I know cars that have done 100,000 + miles and the turbo's are still going. A couple have been running 20+ psi all their lives.
Old Jan 19, 2006 | 08:35 PM
Oranoco's Avatar
Oranoco
25psi on mine and it hasn't spat the turbo out. Sound like they are fishing for a get out
Old Jan 19, 2006 | 09:07 PM
Badman38's Avatar
Badman38
Default Re: Turbo technics say i must have a D/V, ideas please?
cheers troops
i was told by ahmed bayjoo that unless you are running a t4 the t series turbos dont need a dump valve because they dont produce much back pressure.. i fooking hate dump valves but i have to run a valve on my gt series tubo , because of the ball bearing core the shaft is very thin and vince @ universal turbos has seen compressor wheels break from there shaft.. i'm going to run 29psi so i use a tial blow off valve which sounds ok
Old Jan 19, 2006 | 09:15 PM
addiction's Avatar
addiction
i personally dont have a d/v but i do agree with what Rick said!
AJC's Avatar
AJC
What?!
PMSL
the turbo is a stage 2 turbo technics, still t3, now, i ran with out a d/v
for a month and preferred it, ran a lot better and seemed to pick up a lot
quicker, the car is running 21psi, now i get told different things all the time,
technics say i MUST run one but like you say, C & B run with out one,
the oil line has been tested and is pushing out 58psi, engine is 8k old and
everything new, i.e, hoses, oil feed pipe, i have bought a bailey
breather to fit once turbo back on, i dont want a dump valve.
Old Jan 19, 2006 | 09:18 PM
AJC's Avatar
AJC
this will be my 6th
but the first 4 were dodge and were not good as soon as they were fitted
to the car, they were done by a local firm, turbo force, aka turbo farce, LOL,
they alll had inbalanced shafts and could not take the high RPM
Old Jan 19, 2006 | 09:31 PM
Badman38's Avatar
Badman38
this will be my 6th
well i suppose it wont hurt to use one just to see if thats the reason you are going through turbos
Old Jan 19, 2006 | 09:48 PM
Tony Turbo's Avatar
Tony Turbo
I think they are talking out of their arse. I ran 21psi on a stg2 for a matter of weeks before I got bored an went to a stg3 with 24psi, then my conrod snapped
Old Jan 19, 2006 | 10:06 PM
zippyobrien's Avatar
zippyobrien
my daily runner runs 12psi on mfi and i get quite chatter but it is enough to make people look (standard turbo)
on my weekend escort, im running 21psi on a full worked stage 3 with out a dump valve with out any probs. tryed it with a dump valve, it made absolutly no difference.
you cant use a recirculating dump valve with mfi as it will confuse the metering head and technicaly make a massive air leak!!!!
you defo dont need a dump valve!
Old Jan 19, 2006 | 10:07 PM
AJC's Avatar
AJC
well whilst they fix it, i might get it upped to stage 3
Old Jan 19, 2006 | 10:08 PM
zippyobrien
you can use an old amal valve and plumb it on to the vacume for the dump valve. this allws you to turn the dump valve on and off
Old Jan 20, 2006 | 12:36 AM
Combi_Chris's Avatar
Combi_Chris
i run efi, i havent got a dump valve, ive never owned one , and ill never get one , im currently at 18 psi before map after running in and so far , no problems
Old Jan 20, 2006 | 01:27 AM
sufsRS's Avatar
sufsRS
no need for the dump valve simple as, how many people do you know that have had turbo problems due to running a dump valve?
Old Jan 20, 2006 | 08:33 AM
Oranoco's Avatar
Oranoco
Had three DV's including a twin piston Bailey job over a period of 3-4 years and the car was never right with any of them. Best thing i did was file them away in the spares drawer. My Escort doesn' have one and my Fiesta won't be getting one either
Old Jan 20, 2006 | 10:09 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Does the car have an Airleak or something else maybe that is causing the Turbo to overspeed? That seems very likely IMO. It should not be spanking turbo's at that rate, in any case.
Sorry if you already said and I missed, but in what way have the last 2 or 3 failed?
As Tony said, I run close to 2-Bar on what is considered one of the most delicate type of Turbo, the GT Series, and have never run a Dump Valve.
I used to run similar boost levels on my Stage 3 T3 too.
To be honest, yes to run a Dump Valve will increase your Turbo's chances of surviving, but when you stack all the other odds up against it, there are so many other things that can kill your turbo first.
Turbo warranties aren't worth sh1t in my opinion. As soon as a Turbo fails under warranty, it will have mysteriously been subjected to either a 'Foreign body' or 'Oil contamination'. Both of which are hard for you to fight anyway.
My money is on an Airleak. Start with your Throttle-body to Inlet Manifold Gasket.
Old Jan 20, 2006 | 11:30 AM
AJC's Avatar
AJC
Christian and Beccy
thank you, that is getting changed any way as i have a new inlet manifold
to go on, the first 4 turbos where done by turbo force and they did not have a good enough
machine tyo test the turbos to 150, 000 rpm so they were never good enough
Old Jan 20, 2006 | 11:46 AM
Christian and Beccy
#1 in Spelling Club
PLEASE don't fit another Turbo to that car until you have found the cause of the failures. I hate seeing someone have so much trouble. That car should not be destroying turbo's at that rate.
Thats my advise!!
Old Jan 20, 2006 | 01:47 PM
Kop2381's Avatar
Kop2381
As above i think the problem lies else where six turbos Surely thats telling you that there is something wrong whats the chances of cooking six units in under 8000mls without crazy boost id get the turo replaced and then get it booked in somewhere to try and identify the problem Good luck
