rs turbo s2 missfiring ?
Old Jul 19, 2004 | 03:08 PM
RSTurboT34's Avatar
RSTurboT34
Default rs turbo s2 missfiring ?
my car is missfiring like a fooker i have tried everything i can think of plugs /leads/ dizzy cap /injectors / and all the sensors compresion test and there all ok what its doing is missing on no.2 piston when you pull the plug lead off it dont make any diffrence its really pissn me off if i dont sort it soon im gonna sell it
lee
Old Jul 19, 2004 | 03:25 PM
CabrioTurbo's Avatar
CabrioTurbo
well thats got me stumped what happens if you unplug number 2 and put a spark plug on the end of the lead (ie just open to air) will it spark.. i find it quite had to see why one plug wont fire if the rest will.. especially when youve changed the dizzy cap and leads!
Old Jul 19, 2004 | 03:34 PM
RSTurboT34's Avatar
RSTurboT34
it sparks normal like the rest m8 took the injector out to see if it was spraying right and it is ok to
Old Jul 19, 2004 | 06:26 PM
KSA-Cossie's Avatar
KSA-Cossie
Mine did that last winter,changed the plugs and all was fine.
Old Jul 19, 2004 | 06:32 PM
Lee Reynolds's Avatar
Lee Reynolds
Did you change the cap because of the missfire or was doing so anyway? I.E are the leads on the cap in the right firing order?
Old Jul 19, 2004 | 06:47 PM
James Raby's Avatar
James Raby
This was aksed on the RSOC bbs, seems nothing was checked we suggested
Old Jul 19, 2004 | 07:12 PM
Rick's Avatar
Rick
Hi mate - do a compression test on that cylinder.
Old Jul 19, 2004 | 08:10 PM
RSTurboT34's Avatar
RSTurboT34
i have done everything m8 what everyone said made no diffrence one thing i did not mention it runs better when cold and before you say it ive had the mixture setup
Old Jul 19, 2004 | 10:15 PM
Lee Reynolds
And compression on cyl 2 is fine?
Old Jul 19, 2004 | 10:53 PM
RSTurboT34's Avatar
RSTurboT34
yeah m8 compression on cyl 2 is fine
Old Jul 19, 2004 | 11:42 PM
CabrioTurbo
hmmm if it sparks with a plug just 'plugged' into the lead then it must be firing ok.. id say you have some sort of porblem on no2, prime suspect would be head gasket but if compression is ok then i dont know
Old Jul 19, 2004 | 11:56 PM
weegaz22's Avatar
weegaz22
plug gaps correct?
Old Jul 20, 2004 | 07:59 AM
RSTurboT34's Avatar
RSTurboT34
plug gaps yeah i tried the plugs out of me bros turb which run perfect in his but like i said before runs alot better when cold do you think it could be a coolent sensor or sumit or even the fuel dizzy ?
Old Jul 20, 2004 | 08:11 AM
Jon ERST S2's Avatar
Jon ERST S2
when does it misfire? Mine was misfiring on no#2 at 6000rpm due to a valve not seating. Have you tried a bore leakage test?
Old Jul 20, 2004 | 10:14 AM
Lee Reynolds
Exactly my next thoughts john. I was going to say a sticking valve/sticking lifter/or fooked lifter!
Take the lifters out of their bores on cyl 2(inlet and exhaust). If either of them have been sticking the underside of one will be very worn(sometimes rounded off cam). If not it could be a valve sticking!
Old Jul 20, 2004 | 10:27 AM
RSTurboT34's Avatar
RSTurboT34
ok m8 will try it
Old Jul 20, 2004 | 11:01 AM
Jon ERST S2
wow you mean I said something that made sense
Old Jul 20, 2004 | 11:03 AM
Lee Reynolds
Sorry Jon i dont follow you
Old Jul 20, 2004 | 11:05 AM
Jon ERST S2
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
