anyone got a nomad water temp gauge ?
Old Jul 19, 2004 | 02:06 PM
220TC's Avatar
220TC
Default anyone got a nomad water temp gauge ?
the e/l type to be precise.
How accurate is it ? I put one in my s2 erst yesterday and the highest temp I saw today whilst driving to work was about 65c surely thats too low ?
Do you have to use a special wire from the sensor to the gauge because I used normal wire ? Could the way I connected it be making it read low, I used a crimped lug and then a nut on top of that, should I have connected the wire straight to the sensor by another way to get a more accurate reading
any advice appreciated
Duncan
Old Jul 19, 2004 | 03:01 PM
CabrioTurbo's Avatar
CabrioTurbo
dont suppose you could tell me how to wire one up could you ive had mine sitting in my door pocket for about 6 months just not got round to fitting it and there seem to be a lot of connectors on the back
CheeRS
Phil
Old Jul 19, 2004 | 03:53 PM
220TC's Avatar
220TC
pretty easy mate, wire up the relay connectors first, 1 to earth and one to the switched live that switches the lights on. Then wire up the gauge, red to a switched live, black to earth and green to the temp sensor. Then plug the big thick wire into the connector coming out of the relay and hey presto, done
Anyone actually got one fitted and having the same prob as me, ie. low reading of water temp ???
Duncan
Old Jul 19, 2004 | 05:39 PM
220TC's Avatar
220TC
Old Jul 19, 2004 | 06:00 PM
CraigN's Avatar
CraigN
i have 2 of them one readin water temp one reading oil temp
work mint for me
Old Jul 19, 2004 | 06:07 PM
220TC's Avatar
220TC
what sort of temps do you see on the water one ? did you use any type of special wire from the sender to the gauge ? how did you connect the wire to the sender ?
Cheers, Duncan
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
