Revlimitet - on the MFI
I have got a hold off how to change the revlimitet on the MFI setup..
But i don't know what it will change it to......
So is there anybody that knows.....
Here is the pic:
Here is the pic:
that capacitor raises rev limit to 7.2 k fitted it in my xr2 rst as it was cammd and had std fuel ecu.
my new rs has it done too all that happens when they chip your fuel ecu is that bit gets replaced get sumone who is good at soldering to do it
I work for an electronics company i could prob get the caps for ya but if your not good @ soldering dont bother otherwise your fuck the pcb.
Jim
Jim
that was what i was after....
Do anybody knows if you can use others size capacitor to change the revlimit let say to aprox 6800 rpm..
i searchd long and hard and unless you are realy clued up with electrics and could work it out using sum electrical equasions or fancy paying a tuner a oner to chip it to your specifications then no
think std cuts in @ 6.5k which would be fine on std cam if you running big cam run 7.2k ecu and if running std change gear earlier as std cam and turbo your not gaining anything by staying in gear at them revs
Where are you based?
yeah but then u can only run std boost so youl take a while getting to the new rev limit
think i could only run 10psi on one of my stds ecus.
i thought big cams and that are for rst,s running 14psi+
Not something you want to mess about with yourself really if you want the rev limit raised get a tunner to do it
