Engine is in (pic)
Old Jul 19, 2004 | 09:16 AM
Jasesapphy's Avatar
Jasesapphy
Default Engine is in (pic)
I know its not a cossie but as the passionford lot are in to ALL fords i thought i would post this pic
Yes its a 2.0 twin cam
Goes better now with a lightened bottom end and 285cams.
Please dont laugh at the next bit
Runs 7psi at the mo and is good for about 200 bhp
What do you think
Old Jul 19, 2004 | 09:21 AM
Rene's Avatar
Rene
looks good
Old Jul 19, 2004 | 09:22 AM
R4N SS's Avatar
R4N SS
how much was that conversion or did you do it yourself?
Old Jul 19, 2004 | 09:24 AM
Wazzzer's Avatar
Wazzzer
2ltr twin cam with a blower pushing out 200bhp, close enough!!
Old Jul 19, 2004 | 09:25 AM
Jasesapphy's Avatar
Jasesapphy
Its a Turbo technics conversion they done about 30 of them back in the early 90s.
Runs standard compression and low boost which is instant well usually hits 9psi at about 2000 rpm the cams take to limited its not the fastest car in the world gives some people a fright though.
The engine was bought off the boards he takes the credit for the rebuild with cams e.t.c
Old Jul 19, 2004 | 01:13 PM
Jasesapphy's Avatar
Jasesapphy
Just need it to run cooler as 110oC is a bit warm
Old Jul 19, 2004 | 01:16 PM
R4N SS's Avatar
R4N SS
110 thats a bit too hot. Stick a 4x4 cooler on
Old Jul 19, 2004 | 01:22 PM
Jim Galbally's Avatar
Jim Galbally
are those ACTs or Coolant Temps?
those blue hoses look photoshopped weird...
looks cool tho
2 hints tho, if the car's got ABS then try n get some heatshilding put hehind the turbo where its near the ABS block, as in the summer n traffic n stuff it can boil the brake fluid which is a pain in the arse coz u gotta sit n let it cool down again before continuing...
also sitch the dumpvalve n get some chatter!
Old Jul 19, 2004 | 02:43 PM
Jasesapphy's Avatar
Jasesapphy
Cheers Jim, i will get my photoshop and do the boost hoses as well.
Photoshop
Old Jul 19, 2004 | 02:44 PM
Jasesapphy's Avatar
Jasesapphy
Coolent temp 110oC
Old Jul 19, 2004 | 02:45 PM
Jasesapphy's Avatar
Jasesapphy
Oh chatter is bit of a joke on 7psi however if i was running 20psi i would deffo have chatter not DV
Old Jul 19, 2004 | 02:47 PM
Spiky's Avatar
Spiky
whats 110 degrees????
water or air charge temp?????
looks clkean and tidy
Old Jul 19, 2004 | 02:52 PM
Jasesapphy's Avatar
Jasesapphy
Water temp is 110oC
Old Jul 19, 2004 | 02:55 PM
Jim Galbally
jase, the hoses look photoshopped, its weird innit! i think its where the rest of the pic looks B&W but the hoses stand out so much...
and at that level of boost you should still get some nice chatter, n some even better wheelspin
200bhp on that engine is not to be sniffed at, thats bloody good going
Old Jul 19, 2004 | 02:57 PM
Spiky's Avatar
Spiky
can u get a cossie rad on there?????
i'm assuming the cossie one's are bigger
Old Jul 19, 2004 | 02:58 PM
Jasesapphy's Avatar
Jasesapphy
And if it goes wrong it cost the same as a mars bar wrapper to fix.
e.g Last year Sat Morning 10am alternator died, local scrappy Ł10.00 plus vat later up and running fixed by 12.15pm.
Bargain, oh a set of plugs are Ł4.56 and leads are astonishing at Ł14.50.
Old Jul 19, 2004 | 02:59 PM
Jasesapphy's Avatar
Jasesapphy
Spikey
The outlets are different if i remember and a cossie rad is smaller but A LOT LOT LOT more efficent
Old Jul 19, 2004 | 03:01 PM
Spiky's Avatar
Spiky
can u not try and get it to fit???? may help with cooling , and most breakers have then
Old Jul 19, 2004 | 03:05 PM
Jasesapphy's Avatar
Jasesapphy
Look at the basic first i think.
Lower thermostat e.t.c.
The one thats in is a 88oC i have got on thats 82oC but ned to ensure the water temp guage is correct, should be it was from Nomad
JoeyBoyden
Jan 4, 2024 02:36 PM
bigryrs
Mar 28, 2016 09:11 PM
track.focus'd
Aug 12, 2015 05:53 PM
vdubo7
Aug 2, 2015 08:17 PM
