Hot start probs and blowing white smoke
Old Jan 15, 2006 | 10:30 AM
mad ferret's Avatar
mad ferret
Default Hot start probs and blowing white smoke
You may remember that a few weeks ago I had these symptoms and concluded that the head gasket was fooked. Well, I've replaced the head and started her this morning for the 1st time since finishing fitting the new head and I still have the same problems despite having no coolant in there. (I just wanted to check it would start before I filled up with coolant). The smoke bellows out and is pure white.
Your thoughts please?
I recently renewed the air flow meter, should I bleed the injectors through as per a diesel motor?
Could the warm up regulator be at fault?
Old Jan 15, 2006 | 04:59 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
turbo?, much movement in it?
ive had plenty of rsts so this usually frst's still on t2's
they dump oil into the exhaust then as they warm up they plume
this 1 for instance
and the smoke stinks
Kyle Langford
27
Aug 5, 2019 07:54 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Adam-M
22
Aug 10, 2015 10:46 AM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
