s2 flywheel on to s1
Originally Posted by mark@fordrs.org
do i need a s2 starter motor fitting? i have them both so which is gona be best to use
str8 swap afaik. fits into S1 box aswell
I'm planning to fit an S2 clutch (d=220mm) to an MK3 Escort XR3i (original clutch d=200m). I already have the the flywheel, so that the bigger clutch will fit to it, but I was told, that the 220mm clutches are "low-lift", so there can be a problem. (Or I have to change the clutch operating arm as well).
Any experience with it...?
I'm planning to fit an S2 clutch (d=220mm) to an MK3 Escort XR3i (original clutch d=200m). I already have the the flywhell, so that the bigger clutch will fit to it, but I was told, that the 220mm clutches are "low-lift", so there can be a problem. (Or I have to change the clutch operating arm as well).
Just looked............the only variation is in the 88 changeover, difference being the release arm can be removed from the top, but im sure they are the same length etc.
The arm in the car is about 16,5cm long (from the connection to the release bearing to the end), and the one that I got from an MK4 is ~18,5cm.
So you say it wont matter for me. Then what's the difference between them? Its lighter to push the pedal with the longer one?
The longer one (newer one) will make the pedal lighter, but will need more pedal travel to fully disengage.........
Take your pick in that case, my MK3 cabby has a S1 box with the shorter arm, and a 220mm clutch, works fine and the pedal isn't at all hard. You may well find the holes on the gearboxes are different and don't line up if you change the arm for the longer one aswell so bear that in mind
Thanks for all your answers, you helped me to avoid some unnecessary work!
