WHAT FUEL??
Jan 7, 2006 | 12:04 PM
WHAT FUEL??
My erst is running about 230bhp whats the best fuel to put in it?? superunleaded or optimax....also if i was to drive a lond distance with minimal hard acceleration would unleaded be ok or would that cause damage
. cheers
Jan 7, 2006 | 12:13 PM
Do not run it on Unleaded. The other option is up to you, personally I avoid Optimax. I mostly use Esso SUL or BP.
Jan 7, 2006 | 12:28 PM
do u put ordinary superunleaded and an octane booster aswell mate
Jan 7, 2006 | 12:32 PM
Jan 7, 2006 | 12:35 PM
4 star
Most of the time i use good old 4 star as m8s dads garage still sells it but is a tad on the dear side £44 TO FILL MY S1
Jan 7, 2006 | 01:23 PM
i use 99 ron fuel
Jan 7, 2006 | 03:46 PM
Optimax all the way
Jan 7, 2006 | 04:19 PM
Quote:
why do you avoid optimax?
Jan 8, 2006 | 07:13 PM
for example my mate had to run lees boost as his car was dettin on super unleaded,optimax cured this
Jan 8, 2006 | 07:49 PM
can normal unleaded damage your engine? at 14psi? Cheers
Jan 8, 2006 | 07:51 PM
could do yes.
stop being cheap and put at the min SUL in.
optimax is best
Jan 8, 2006 | 08:05 PM
Just personal preferance. My car was mapped on Esso SUL so that's what I run it on
Jan 9, 2006 | 12:31 PM
oh ok lol, had me worried i only ever ran on optimax
didn't know you could map to a specific RON. Impressive
Jan 9, 2006 | 12:35 PM
My engine totally standard.
Been told that 2-1 is ok ( 2 unleaded to 1 super-unleaded )
Jan 9, 2006 | 12:42 PM
Quote:
Originally Posted by Combi_Chris
i use 99 ron fuel
yeah ive found 99 ron. Try tesco,s . standard saff went and felt very strong with it
Jan 9, 2006 | 12:54 PM
Jan 9, 2006 | 09:38 PM
check last months performance ford. they did dyno test on fuel. stay well away from spermarket fuel its crap. Big gains can be found from fuel.
Jan 9, 2006 | 10:19 PM
Only unleaded on S2. The head has hardened seats. Fifth gear did a test on different fuels. Optimax was best, giving most power on a WRX. This means the ECU sensed the quality of the fuel and adjusted the ignition. RST doesn't have a clever ECU but run Optimax since it's best.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
20/20 vision
Sep 29, 2015 11:27 AM
