Immobiliser/Alarm Problem
Old Jan 5, 2006 | 07:51 PM
aldy's Avatar
aldy
Default Immobiliser/Alarm Problem
Hi, Don't know if anyone can help, just rebuilt a S2 and after connecting everything up I can get the engine to turn over and the doors lock and unlock by the remote, the electric windows work as well as the interior light....................but I have no dash warning lights and no fuel pump whirring etc etc. The alarm is a Maystar and the Immobiliser is an Auto watch. There is a aftermarket switch fitted under the steering wheel but this makes no differance whatever position its in.
Old Jan 5, 2006 | 08:39 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
left a wire off the battery (maybe fitted it to neg rather than pos?!?)
or coil isnt connected (wires maybe damaged) try putting a wire from the pos side of the battery into the black wire side of the coil and refitting plug, see if lights come on then (so the pos feed is trapped in the coil black wire side under the plug, if u follow me ) lights shud then lite up
Old Jan 5, 2006 | 08:52 PM
aldy's Avatar
aldy
I have got two brown wires left but when connecting these to the pos terminal they stopped the remote lock/unlock working and still didn't light up the dash lights
Old Jan 5, 2006 | 09:27 PM
1.9 xr2 on 40's
st170 breaking
brown is earth in cars mate, if they have rings at the ends screw em to the body of the car
Old Jan 5, 2006 | 10:36 PM
aldy's Avatar
aldy
That might be the problem then, thats the trouble when you try and finish off someone else's project, but I will get there in the end
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
