Looking for philm
Originally Posted by big_wig_074
want me to text him?
Jim
he knows your after him chap! but he works some weird shifts! as far as im aware the rods are fine, dunno about pistons tho as the head on a cvh makes the cr different IIRC!
needs to be lowered a bit more on a zvh
Sorry dude, didnt see this post
Eagle rods are fine, in a mondeo block (you can only use mondeo blocks for ZVHs). But, you need to remember you want a Focus type piston, if you have Eagle rods and a Mondeo piston, the combined rod and piston length will be altered and not work!
So get a Focus type piston. As for CR, thats up to you to decide what you want to run, and have the pistons machined and measured to suit. I'd imagine a piston with say an 8.2:1 CR in a Focus 16v head, would be about right, be in the 7.X range (without working it out) when using a 8v CVH head.
Where's Sketch with his CR Spreadsheet?
PMSL, here i am
Roughly speaking, if you bought a set of 8.2:1 CR pistons for a 16v zetec, assuming the combustion chamber volume of the focus zetec head is similar / the same as the mondeo zetec head.....
Then i think that would give approx 7.3:1 CR if the zetec head was swapped for the CVH head.
This is roughly speaking - as i said above, im going on the presumption that the heads are similar between mondeo and focus.... anyone know?
Red16
16
Feb 3, 2005 08:42 PM
dunno why i bother
