s8 users
Old Jan 4, 2006 | 03:23 PM
the original's Avatar
the original
Default s8 users
who has got an s8 and who mapped it?
if you mapped it yourself how did you get on?
especially with using the narrowband control switched on
i need mine mapped by the end of Jan for a magazine feature
who would you recommend to do it?
or anybody got any s8 maps they did themselves i can take a look at?
and please don't turn this into a post dissing s.e.c.s , i have never had a problem with simon, all my technical enquiries got answered fast by him
cheers
Old Jan 4, 2006 | 03:26 PM
GARETH T's Avatar
GARETH T
ive started to map a s8 car,, but the builder of the car had a few problems with the pick-ups he made so i had to stop!
really like the system,, nice and easy, and straight forward
havent wired the lambda into the ecu yet
Old Jan 4, 2006 | 03:27 PM
Disabled Account's Avatar
Disabled Account
Default Re: s8 users
I have an S8
Mapped by Karl Norris = Norris Motor Sport.
Old Jan 4, 2006 | 03:29 PM
peteh's Avatar
peteh
What's an S8? pectal?
Old Jan 4, 2006 | 03:30 PM
GARETH T's Avatar
GARETH T
not its a secs ecu, make to just plug ans play into a cossie wiring loom
Old Jan 4, 2006 | 03:33 PM
Ive only "played with" mapping mine, not done it fully yet, but as gareth says, its very easy to use.
Simon (SECS) will map for a fee i believe, but im not certain, and as Doug says Karl knows his way around S8 and is obviously a VERY well respected mapper in the cossie world.
I would try Karl first if i were you mate
Old Jan 4, 2006 | 03:38 PM
ECU Monitor Enthusiast
When using any type of system using lambda sensors as on ANY ecu,
you must map the car first THEN enable the lambda band control.
This is because the ecu needs something to fall back on
should the sensor fail and also it is a base map that will be
corrected by the ecu using the sensor.
This is true for both narrow and wide band sensor ecu's.
The S8 lambda control default settings should work fine
once you have mapped the car, just enable the feature.
Only should the idle hunt will you need to adjust the
loop time values.
Currently the S8 ONLY supports narrow band lambda BUT
there is a new windows software upgrade which will include
many new features such as WIDE BAND closed loop, ALS,
data logging etc.. (Upgrade free )
Old Jan 4, 2006 | 03:39 PM
Porkie's Avatar
Porkie
I run a SECS S8 and have had maps from Both Harvey Gibbs and Karl Norris on it.
Old Jan 4, 2006 | 03:40 PM
Looking forward to this upgrade simon, sounds the tits
Good point to mention about the lamda, i know people who have relied on it and not got a decent base map under it, one of them had a sensor failure and didnt even make it home
(not on s8, on dta)
Old Jan 4, 2006 | 03:42 PM
GARETH T's Avatar
GARETH T
i hope im in your mailing list
the original
Thanks for all the replies, now gonna e-mail Karl then
cheers Simon, is the update finished then or is it coming?
Old Jan 4, 2006 | 03:49 PM
GARETH T, The Original,
I have a PROVISIONAL version ready for BETA testing, works on ALL
versions of windows and uses serial ports and/or USB for the ecu interface.
Plus allows you to create a graphical customised dash with virtual gauges.
I will post up a link to my web server later this week although some
features are disabled at the moment as I have not completed my
final tests.....
... Once I have done some work for Stu
Old Jan 4, 2006 | 03:51 PM
Simon im happy to take a BETA version that comes with no warranty or guarentee etc
Old Jan 4, 2006 | 03:52 PM
GARETH T's Avatar
GARETH T
thanks simon
Old Jan 4, 2006 | 03:55 PM
the original
e-mailed Karl, hope he's not too busy to map me up
Old Jan 4, 2006 | 04:08 PM
Porkie's Avatar
Porkie
Guys, this is a RANDOM change of direction in this thread I realise... BUT (and this is a weird small world moment) it turns out the house in the rear of my signature picture is Simon from SECS own house. Previous owner was his neighbour!
Well I thought that was freaky deaky anyway
Old Jan 4, 2006 | 04:10 PM
GARETH T's Avatar
GARETH T
that is a little strange
Old Jan 4, 2006 | 04:15 PM
Yeah, that skybus lowered the tone of the neighbourhood
Nice colour though
Old Jan 4, 2006 | 04:16 PM
Badman38's Avatar
Badman38
cheers
i run an s8 simon done me a good base map and karlos mapped it running closed loop lamba and water injection
Old Jan 4, 2006 | 06:42 PM
Fiecos Dan's Avatar
Fiecos Dan
i played quite alot with my s8, and got a few maps now for 8inj cars running gt30.
Upgrade sounds promising Simon.
Old Jan 4, 2006 | 06:57 PM
Thanks all for positive replies
Been a struggle this year for me one way or another but this product
is my baby and I will always continue to evolve it.
May make some money out of it one day
The software had to be upgraded due to Microsofts anti DOS and serial port
policy which for me is a sad thing being brought up on them
Now added features that make it comparable to the higher spec rivals
but much cheaper.
Hopefully, if all goes to plan During this month I will have a new
set up for ecu manufacture like the ecu monitors are made now
so removing all my day to day headaches with improved sales support
and a new improved price.
If anyone has any SERIOUS suggestions for features/modifications
they would like to see, now is the time to speak up.
Old Jan 4, 2006 | 08:45 PM
the original
great. Tell us more Simon
what new features?
Old Jan 4, 2006 | 09:08 PM
_Ben_'s Avatar
_Ben_
oops
Old Jan 4, 2006 | 09:09 PM
_Ben_'s Avatar
_Ben_
Originally Posted by _Ben_
oops
misposted, apologies.
Old Jan 4, 2006 | 09:18 PM
Stu @ M Developments's Avatar
PassionFords Creator
Quote of the topic.....
Old Jan 4, 2006 | 09:21 PM
Mentioned a few features but here are a few more details....
MULTIPLE MAPS SWITCHING EXPANDED TO 16.
You could have upto 16 completely different set ups in ONE ecu
and change them at a flick of a switch while running.
(Can be configured to not switch unless stopped first)
Current version only allows 2 complete set ups.
CLOSED LOOP BOOST
Fully PID controlled closed loop boost control.
Using air injectors or high speed valve.
Currently only allows mapped boost percentage levels.
CLOSED LOOP WIDE BAND LAMBDA
As title with autotune for mapping.
Using independant wideband sensor or external wideband such as
tech edge etc...
ALS
As above. Been available for a while but never released software.
DATA LOGGING
Upto 1 megabytes in ecu storage. (flash memory)
(about 30 to 100 minutes depending on configuration}
Unlimited logging (subject to hard disk size) if online with PC.
Data playback via excel and/or powerpoint.
IMOBILISER/ANTI HIJACK FEATURE
Cant say too much here to keep it secure
FULL SUPPORT FOR EEC4 EQUIPED CARS
Allows retro fitting to these cars on existing wiring loom and sensors
with ease.
(Except map sensor of OFAC which will need replacing)
SUPPORT FOR FULLY SEQUENTIAL COIL PER PLUG
As above.
WINDOWS DASHBOARD
Allows you to create a customised dashboard display on your laptop
with virtual dials etc...
For the future......
DRIVE BY WIRE THROTTLE
Will be installed on my car during the summer for testing..
Dont know if it will give me any actual benefits yet but will look
good if nothing else
All software upgrades will be free and 99% of ecu's out there already
can take advantage of these when available and can be uploaded
by yourself.
Old Jan 4, 2006 | 09:29 PM
3drstretch's Avatar
3drstretch
Simon can you please read/answer my Pm.
Old Jan 4, 2006 | 09:32 PM
GARETH T's Avatar
GARETH T
simon i need all these now
bloody impressive simon,, i cant wait too have a go
can you give us a screen shot of the windows software?
Old Jan 4, 2006 | 09:47 PM
GARETH T, will upload a preview tommorrow - Link on this thread.
3drstretch, Sorry mate, not at my own computer at the moment.
SO I didnt get the notification, will look now.
Old Jan 4, 2006 | 09:54 PM
the original
Absolutely Awesome
especially loving the windows dashboard
and the closed loop boost
and datalogging
and... well everything
any plans to incorporate in the EGT stuff?
Old Jan 4, 2006 | 10:22 PM
Mark THESE words...
YOU WILL ALL BE DISSAPOINTED.
Old Jan 4, 2006 | 10:36 PM
Originally Posted by Bosch-Man
Mark THESE words...
You told me that about the ECU and you were wrong
You told me that about getting hold of Simon and you were wrong
You told me that about the level of help Simon would give and you were wrong
And by the sounds of the new features you are wrong again.
At least you are consistant Phil
Why dont you do the thread starter a favour though and respect his wish for this NOT to turn into a slagging off post?
Just for once remember that pasisonford doesnt exist for you, it exists despite you
Old Jan 4, 2006 | 10:59 PM
Phil,
Thanks for your kind input, I will BTTT all your threads and comments
you made previously about the ecu and all were positive until I caught
you out trying to pass off Karls mapping as your own work.
I have saved the pages just in case someone conveniently edits them
Old Jan 4, 2006 | 11:01 PM
PMSL @ SECS
Phil doesnt like to remember the past, he always ignore that after he met me he posted on here saying how sound i was etc, and now says he always thought i was a cock, he likes to keep rewriting his own past for some reason!
Old Jan 5, 2006 | 09:51 AM
Ok, here is a sneak preview of the windows version of the new S8 software.
UNFORTUNATELY, you wont see much unless you are connected to an S8
and even then you need an upgrade to access all features but this
wont be released until I am ready in the very near future.
For existing users, this will NOT upgrade any software you have
or permit any changes to your ecu maps (deliberate lock out) but allows
you to go online to the ecu IF your software version currently allows it.
This is more of a data link test version as it allows connection to all
windows com ports however they are configured.
The com port issue is probally THE main technical complaint most people
has fed back to me about the existing PC software.
You should be able to log on and display live data at the very least !!!
If you try it on your S8, please lete me know how you got on
with all details of...
Windows version,
Com port set up (Should work on USB to serial converters now )
Here is the link...
http://www.s8ecu.co.uk/S8win.zip
This will need unzipping - No special installation requirements needed.
When the final upgrade is available, Most users will be able to perform
the new software installtion by themselves without even opening
up the ecu at all or the need to remove it from the car.
*** I should point out, this is all aimed at EXISTING users of this product.
The ecu is currently not available as a new manufacturer is in the
process of being set up. I cant give a date at this point in time as it
is out of my hands.
Old Jan 5, 2006 | 10:02 AM
Nice one simon, will probably give it a go this weekend
Post some screenshots though for now?
GARETH T's Avatar
GARETH T
looks tidy simon,, will have to pop round too my mates car later and have a look
Old Jan 5, 2006 | 10:19 AM
foreigneRS's Avatar
foreigneRS
Testing the future
looks good simon - will test at the weekend for you on my laptop running xp with pcmcia/rs232
Old Jan 5, 2006 | 10:25 AM
3drstretch's Avatar
3drstretch
Thanks for the reply yesterday Simon.
Another question there on PM now.
Old Jan 5, 2006 | 10:26 AM
Look ok to me at first glance.
would have been nicer if the background file was a .jpg in the same directory though, so its changeable?
But thats splitting hairs.
Blimey, looks like that tosser Phil is getting better he was wrong in RECORD TIME this time
