Calibra Turbos
any info on them? any sites?
a good mate of mine has bought one for 500 smackers, no MOT, fairly tidy, seems to run ok, if a little noisily (sort of grinding noises undernieth).
nice interior, new turbo...
it has coosvaux stickers on it, anyone heard of them? any good?
what size turbo? t25? looks alot smaller than my t3...
what is the C20LET like? Transmission?
book times? etc.
pretty much kept up with him up this hill in my s2, both reached 110 at the top (its a private hill
), though i was quite impressed in the launching, what with 4x4...
whose owned one?
dre
book times? etc.
whose owned one?
dre
500 is cheap will break for over a grand for just engine and gearbox
cossvaux
they dont run a t typr turbo they run whats called a kkk16 it is smaller that a t3 will give up at around 300bhp if you have a good one at about 6k rpm on standard cams
the transfer box is utter crap they have a oil seal in them that goes and causes the box to spit its guts out
if there is a problem with the powersteering IE. low fluid this will damage the box but if you want to get rid of that problem just remove fuse 19 turning back fwd
book times = crap but cheap to tune
cossvaux
Might not mean they have done any work on it?
book times? etc.
whose owned one?
dre
book times? etc.
whose owned one?
dre
Yo can easily get 280bhp out of them with a set of chips and a bigger intercooler
absolute bargain if u ask me, but im a little worried about its transfer box...
sbd16v
so if fuse 19 is removed, it'll be fwd? meaning the transfer box will not be in use? sorry if i sound thick, but my personal experience is with fwd escorts...
Nice price
Has it got leather at all? cos thats another £150-£200 depending on condition
I would sell the engine for £1k on its own, box £300-£350 depending on the current market, the rest isn't really wanted by anyone.
Originally Posted by Snowy_Astra
Nice price
hes gonna be a happy chappy!
oh yes, it has a pretty clean full heated leather interior aswell...
im pretty jelous tbh...
brakes fetch some money too, so do the wheels, and most of the panels and bumpers will sell but not for a lot.
the engines are great for 280bhp, BETTER than a stage 1 YB in fact.
more economical, less lag and boost from lower RPM too.
its going much past that which gets expensive.
Bargain, as said if its pish as a car you could triple your money selling parts
Cossvaux.....if I remember there was praise for the young mechanic there & he left & now its unheard of.....something along those lines!!
If theres noises from underneath then it could be the TX box on its way!! These are not cheap to fix!!!!
it had been standing for a month or 2 in the workshop, when he started it it sounded sweet (better than my cvh anyway). stunk abit when he floored it, but it was only a 10 mile drive, and he said something about putting some damp-start in the bores
bollocks, i finally had a faster car, now he does this...
he'll probably blow it up soon anyway if he drives it like he does his 318, always off the limiter, in his pathetic attempt to get the back end out!
www.migweb.co.uk are pretty hot on their Vauxhalls. Pretty good bunch of lads over there as well.
Sounds like a bragain even if your mate strips it and sells it in bits
A new transfer box from Vauxhall will set you back around £3000 fitted and even a reconditioned one will cost nearly a grand.
Even if its gubbed, he still got a good deal!! & the car will run ok on FWD...infact alot of owners opt for a locked box when theres go!!!
If its 4x4 you are meant to rotate the wheels regularly....this helps preserve the life of the nasty transfer box
nice cars baragin price, back in my vx days i was offered a k plate non runner for 800! if its like the 2.0xe red top then the head can go porous and they run a high comp standard so can easily blow head gasket
Originally Posted by Dan
About the only thing with more rust than a Ford! Just look at their rear wheel arches
unlikle ford when vauxhall fuck up at least they do something about it
The TXB's are ok IF you look after them properly!!!
They may not be the strongest, but they certainly arnt as bad as people make out.
I bet most of the people who say they are crap have never even owned one
I had my rst a while back now , and a friend of mine had an astra gsi which got spanked off me on regular occasions
My rst had 156bhp@wheels with not alot of boost , so anyway to cut a long story short my friend bought one of these calibra turbo in a horrible green colour and says hes gonna destroy me know , so on the bypass coming out a roundabout and sent it 3rd 4th 5th and i hurt him bad
Think he done some transfer thingy a couple of monthes later then a turbo
Most of all the look shit
My rst had 156bhp@wheels with not alot of boost , so anyway to cut a long story short my friend bought one of these calibra turbo in a horrible green colour and says hes gonna destroy me know , so on the bypass coming out a roundabout and sent it 3rd 4th 5th and i hurt him bad Think he done some transfer thingy a couple of monthes later then a turbo
)he wasnt pulling away thats for sure.... cant say i hurt him bad though
So let me get this straight my S2 rst running 14psi , would have done the same to a stndard escos
Im amazed it makes 156@wheels if its only running that spec.
But a standard calibra turbo and a standard escos are pretty much on a par in a straightline race mate yes, so if you beat a (properly running) calibra turbo then you should do the same to an escos.
The escos is slightly more powerful but is heaver and less aeroydnamic (a LOT less aerodynamic if its got the wing!)
Originally Posted by timrud
I've got a transfer box, only though it was worth £60
Cheres for pointing out its worth a bit more Chip!
i only want £50 for mine cus i cant guarntee it, even though it came from a well known mig member
the calibra users the same floor pan from the cavalier and so a cavalier transfer box will fit if u need one that is and also u aint supposed to lower them too much which definately knocks the transfer box out. i think u can get a camber kit to resolve this problem though.
£500 is a very good buy though
remove fuse 19 and run it without the 4x4 system. its shit and would break anyway.
The PAS system is connected to the 4x4 so u need to reroute some pipes to get the PAS to work if the 4x4 is gone.
I used to have a detailed website on the vaux 4x4 system, but t'was a while ago.
get onto migweb and have a lookie there
transfer boxes are the weak point, apparently when you change the tyres you have to change all for so they have level tread cos that can make the transfer box pop, ive never owned one, ive never owned a vauxhall, but a lot of my freinds have, and this is info they have told me.
JK12
33
Apr 26, 2021 12:09 PM
