saph headlamp removal
Originally Posted by slowpoke
how do you get the feckers out ?
matt
matt
One into inner wing(need to remove indicator),one through bracket where grille attaches,one through a bracket into inner wing below back of light where you change bulbs.
they are so easy to get out.
1>take out middle grille 2 screws and slide slighty to left to un clip
2>pop out indicator
3>remove wiper blade and hose
4>carfully prise lower strip out of bottom of h/lamps and unclip eiter side near indicators
5>undo 2 10mm bolts under headlamp and move wiper motor out of way
6>now the 3 bolts hoding the lamp in 1 at top.1 where the centre grille was and 1 at the back of h/lamp where you would change the bulb
7>un plug wiring and out it comes
hth
mark
2>pop out indicator
hth
mark
see those wipers and front grille piece under the light screwed me up aswell, i got the grille strip half out but then gave up and tried to put it back together only it wouldn't go back together properly and the plastic strip under the light is at a angle and looks shit!
cossie330
Oct 7, 2015 08:22 PM
Fudgey
Sep 17, 2015 01:06 PM
