3dr front window removal
Old Jan 2, 2006 | 05:28 PM
3dr wixsy's Avatar
3dr wixsy
Default 3dr front window removal
Sorry 4 putting this in here its just that ive now got tomorrow off and i need to know tonight, how do you get the front 3 dr glass out without smashing the glass
Old Jan 2, 2006 | 05:29 PM
are you putting the same glass back in?
Old Jan 2, 2006 | 05:40 PM
TrickyDicky's Avatar
TrickyDicky
Default Re: 3dr front window removal
remove door card etc, and the 2 straight window rubbers that sandwich glass at base of window.
the rest is from memory so excuse me if incorrect, lower the motor to near bottom limit then you should see 2 arms off motor fitting to bottom of glass, these can be gently prised off with large screwdriver etc, there basically a spherical ball push fitted into plastic grommett so will be a tight fit but do lever out.
hth
Tricky
Old Jan 2, 2006 | 07:48 PM
3dr wixsy's Avatar
3dr wixsy
i take it the glass then slides out the top. polycarbonate windows to go in so all the motor etc will come out. does the bottom runner that holds the glass come out with the glass or do i have to separate them,
Old Jan 2, 2006 | 08:00 PM
TrickyDicky
glass then comes out the top, the bottom runner is bonded to bottom of glass.
hth
Tricky
Old Jan 2, 2006 | 08:02 PM
3dr wixsy's Avatar
3dr wixsy
thanx mate, lets see how i get on
borboyous
Aug 22, 2015 11:17 AM
C2 MAK
Aug 20, 2015 09:46 PM
track.focus'd
Aug 12, 2015 05:53 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
