what to do zvh or cvh
Went to pf meet at weston last night had a blast against audi tt on the way home and the oil light decided to come on @5000RPM IN 5TH
. Although its still running it now sounds like a tranny diesel ,want to no would it be best to rebuild the cvh upgrading it at the same time or build a zvh what do you think, cheers andy
If your going to do a zvh, Do a full on 16v instead, Better power options, And you havent got the problem of having an inbread engine
All depends on how deep your pockets are and what you want from your engine at the end of the day
For 200bhp I would just go with a good quality rebuild with new low comp pistons and new standard rods (if the old ones are past it) ARP rod bolts to help keep it all together. New oil pump and water pump (they are only cheap) and a full bearing set. Having the cracnk reground wouldn't do anyharm either. This should see you fine for 200bhp
Originally Posted by ballin
depends on budget, power expectations etc.
easier to get more power out of a zvh but that also means costs more!
Stay CVH. Both the CVH and Zetec rods are on their knees around 250bhp so there is no benefit going zvh other than having a huge torque spike to make you break traction and feel like you're going fast.
For 200 bhp, do a full (meaning everything, oil pump, water pump etc) bottom end rebuild with ARP rod bolts on the standard rods. Keep the compresion around 8:1 (standard is 8.3:1) using Mahle cast pistons. The crank will require a regrind and polish and the bores may require re boring. At a minimum they must be honed. Refurb the cylinder head (the ports can stay standard) and fit a cam and vernier pulley. Get a stage 3 turbo (T3 still). Get it run in then set up.
Have a look through this thread. It gets a bit interesting about half way down the first page and again on the second page. This engine went on to produce roughly 230bhp with a 5th injector.
https://passionford.com/forum/viewto...889&highlight=
mk3ste
Oct 17, 2021 10:09 AM
TPM961
Jan 15, 2018 10:50 AM
