help need with some bits on my s1
right people i have a few questions that i need a answer for may be u lot can help
if im going to run the car at 14 psi wot should i retard the ignition timming to..
eg 10 degrees before tdc
second one
apparently u can change the camber of the frnt wheels buy adfjusting the anti roll bar is ths possible as i have one wheel with slightly more camber than the other
please help
cheers dave
second one
please help
cheers dave
11degrees tdc is with vacume blocked when timing the car, and 12degrees with vacume unblocked (or vice versa) this is std ignition set up.
dont do it yourself, get someone who knows what their doing, or it may end in tears!
cheers dud e thats just std setting mate tbh i can do it my self i own this company
www.hybridpaintworks.com
To change the camber u need some adjustable TCA's, OR (as someone suggested to me) hack your top mounts off, weld in some rs1600i top mounts and then you can get top mount adjusters and run bilsteins (needless to say i didnt do the latter)
vroooom ptssssh: I didnt know u could set the timing with the pipe still connected on the ECU?
TPM961
Jan 15, 2018 10:50 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
