Daft question about a dizzy
Does the dizzy cap actually do anything apart from cover the dizzy?? For example, will changing the cap do anything to help if i need a new dizzy??
Am showing my RS knowledge now
Originally Posted by Brookesy
the rootor arm sends currnt throughh it to the leads
Or your car will be missing/won't start when you swap them over
I'm kinda on my own with this one as i don't know anyone with any better knowledge than me
you must be a tim them does not have a clue
basically your leads connect to the cap in a specific order in which the engine fires, make sure when you remove the cap that you leave the leads connected to the old one, remove one at a time and transfer them to the new cap in the same positions as they were on the old cap. rotor arm is a simple pull off and push in fitment.
The most important part about this convo is the fact that no-one has told the guy that after changing the dizzy you MUST! make sure that the advance is correct on the dizzy or you will not only be finding it hard to start or drive but it could also damage the engine.
IMO if you have no idea, get a pro to check the settings once you have finished messing about.
Regards
Regards
Regards
Regards
Thanks for the replies folks, me and my haynes manual will have a go!
fourth in the spl still hurting then?
its a piece of piss changing it just three bolts mate, make sure the dizzy cap is dry when you put it on bit of wd40 does the trick and make sure its times as said above 12 degrees btdc if your running a standard cam
