PROBLEMS!!!!!!!!
Old Dec 31, 2005 | 12:37 PM
Josh S1's Avatar
Josh S1
Default PROBLEMS!!!!!!!!
Need help!!!!
My bro has got a Series 1!!
We think its had a fuel leak, but there IS fuel in the car!!!!
Drivin to get a new fuel line, an the Car Dies!!!!!
Could this b somethin 2 do with the fuel line not givin enough preasure 2 put fuel into the engine?? Or could it b somethin else?????
Thanks!!!!!
Josh!!
Old Dec 31, 2005 | 01:15 PM
DazC's Avatar
DazC
If it's got a leak you really shouldn't be driving it with hot exhaust pipes around!!!!
The main fuel line from the pump to the filter will be carrying best part of 6 bar of fuel pressure. A leak will cause it to spray out like a hose pipe and the pressure to drop.
Old Dec 31, 2005 | 03:07 PM
SafeChav's Avatar
SafeChav
Any ideas where the fuels entering the car, thats a very strange one!!
I wouldnt drive it as DazC said thats suicidal!
Which pipe have you broken or dont you know yet?
Old Dec 31, 2005 | 03:54 PM
Josh S1's Avatar
Josh S1
Dont no yet!!! LOL
Its in the garage now, so were goin 2 look at it 2moro with a slight Hangover!!! LOL
Cheers lads!!!
Old Dec 31, 2005 | 03:56 PM
SafeChav's Avatar
SafeChav
Well if your guna be hungover just remember not to spark up while your having a look lol
Rather than run it, bridge the fuel pump relay so the pumps running without the engine being on, bit safer than fuel spraying onto a hot exhaust.
I expect your problem will more than likely be one of the push on pipe connectors, my A reg cabby had a leaky one after i sorted the low fuel pressure problem, although mine was only weaping.
Give us a shout if u need anymore help
Old Dec 31, 2005 | 04:45 PM
Josh S1's Avatar
Josh S1
Dont Smoke so i should b alright!!! LOL
Will do mate!!!!
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
