220-240bhp
what mods would you suggest to achieve this?
av got s stg2 turbo would this be up to the job?
if so:
low comp or standard?
cossie managment, fifth injector, or stand alone managment?
also where do people stand on the rods-ive heard these are a weak point
so wots available to sort this?
i also want to keep it 1600
any help would be greatly appreciated
if so:
Providing your engine was in good nick I would
Go with:
Decent exhaust
Panel filter in drilled air box
Front mount intercooler (GRS/ProAlloy/Pace etc)
Chip
-31 actuator
I would drop the compression on a set of pistons (not decomp plates) and fit ARP rod bolts to help keep it all together)
18psi or so should see you pretty close to 220bhp. Don;t forget to sort your gearbox out or you will eat it in no time and make sure you upgrade the brakes.
I'm running 250bhp through my pretty standard rods. Saying that they are on my list of jobs to do
Go with:
Decent exhaust
Chip
-31 actuator
as oranoco said, get a decent chip, high boost but be careful not to melt the engine, Mahle pistons are good, its what im using and no problems so far, and if your looking for a good intercooler for the money GRS is the way to go, cost less than the others but isnt quite as good as pace and pro alloy, Also as far as the gearbox goes, i shit my standard one out after about 3 months, now ive got a geartorque fully uprated one, Cost me Ł1000 but havent had a single problem with it since, You will need an uprated clutch to, get paddle as you will probably find and organic will start to slip after 200 + Bhp.
one of me mates just finished runnin in his rs turbo rs turbo!
standard bottom end rebuilt! 1600!
area 6 cyl head
kent cvh 35 cam kit! No vernier!
cosworth 4x4 turbo with 360 degree brg!
l8 cosworth management runnin yellow injectors and a pectel board!Odd kid system!
and a half size pace intercooler!
it was mapped at 245 bhp and 238 lbs of torque!
it pulls to the rev limiter in 5th which is set a 7200!
and belive me it worried some big boy cars at a track day at brands and donnigton
he s just brought some arp rod bolts for peace of mind!
area 6 cyl head
Do not use a paddle clutch, use the AP Organic Kit. Compression should be left standard. You won't make 240hp with a std head on a stage 2 turbo, 220 at the very most, more like 210.
area 6 cyl head
area 6 cyl head
but its never been on the rollers [ YET ]
So i dont know where that comes from!
Combi_Chris
i like drivin his motor! alot more rev happy compared to you last zvh lump!(RIP)
your right about one thing it does cost less than the others
I have to say that the GRS absolutely WALKS OVER the Pro Alloy cooler for Charge Temps.
If anyone wants to make an issue of the flow thing, then I would be quite happy to carry out a back-to-back Rolling Road test using the 2 coolers and no other adjustments. All you need to do is all club together to pay for the dyno time and someone lend me a Pro Alloy cooler.
That would prove it and you would all have an answer helping you with which to buy. I know where my money would be (and I bet Tony would back me up on that).
As for making that power, 240bhp is not to be taken lightly. I would definately say a Stage 3 turbo is needed. I ran mine to 260bhp on Standard Rods, Machined Mahle's and a Stage 3 T3 without a 5th Injector. It also did 150+mph on that spec.
BlueSmoke
78
Sep 13, 2006 10:09 PM
Rossco
18
Jan 8, 2005 03:59 PM
