Starter motor bolts
Old Dec 27, 2005 | 09:18 PM
RST Ski's Avatar
RST Ski
Default Starter motor bolts
what size are they and is it best to remove the starter from above the car or below? easy job?
Old Dec 27, 2005 | 09:24 PM
Micky's Avatar
Micky
They are either 17mm or 15mm,cant remember.Do it from below the car,and its a tricky job as space is limited,but it is do-able.Have done it 5 or 6 times myself.Regards Micky
Old Dec 27, 2005 | 09:25 PM
antony215's Avatar
antony215
Escort Rs Turbo
I thought they were 13mm
Old Dec 27, 2005 | 09:27 PM
Micky's Avatar
Micky
They could very well be,I cant remember Regards Micky
Old Dec 27, 2005 | 09:29 PM
Moondust_crust's Avatar
Moondust_crust
think there 13mm mate, proper heavy duty and tiny threads, easily do-able just watch the zorst...........
cheers mark.
Old Dec 27, 2005 | 09:30 PM
Tim's Avatar
Tim
13s same as bell housing bolts
Old Dec 27, 2005 | 09:40 PM
RST Ski's Avatar
RST Ski
basicly on friday me car wouldnt start, sounded like starter motor, pulled the bonnet n thought id give the starter a bang but found it actually loose! could wiggle it up n down with my hands so was hoping ill jus be able to tighten the bolts up, hoping this is why the starter was locking up. what you think? will i be able to nip the bolts from above?
Old Dec 27, 2005 | 09:46 PM
antony215's Avatar
antony215
Escort Rs Turbo
you can get to two of them from the top but the other one you need to do under the car
Old Dec 27, 2005 | 10:04 PM
RST Ski's Avatar
RST Ski
Old Dec 27, 2005 | 11:44 PM
SafeChav's Avatar
SafeChav
Hopefully tightening it up will be ok, but the mounts may be worn as it bolts to the gearbox and it is only made of alloy. Should be ok though, as stated theyre 13mm.
bobsworth
77
Mar 24, 2016 09:30 PM
A.t.p
Oct 23, 2015 07:54 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
DavidK
Sep 27, 2015 02:55 PM
little bram
Sep 27, 2015 07:45 AM
