MSD Stage 3 Closed loop setup L8 (Sold)
Old Dec 27, 2005 | 01:53 PM
silky16v's Avatar
silky16v
Get on That!
Default MSD Stage 3 Closed loop setup L8 (Sold)
Full stage 3 setup L8 from MSD has done only 500 miles less than a month old
3 bar
4 Bosch 803 injectors
Stage 3 Chip
all fitting instruction, boxs and reciept from STU@MSD
£ Sensible Offers
Also have brand new lambda sensor to go with this setup genuine ford
£85.00
Old Dec 27, 2005 | 07:10 PM
bud-weis's Avatar
bud-weis
Football Cwazy
is this WITH an ECU ? if so will you split
Old Dec 27, 2005 | 07:47 PM
silky16v's Avatar
silky16v
Get on That!
no it's not with an ecu
Old Dec 27, 2005 | 09:14 PM
bud-weis's Avatar
bud-weis
Football Cwazy
ok mate, so you get ;
3 bar
greens
stg3 chip and.......
(presumably some gizmo to run closed loop??)
just to help with the sale so people know what they are getting
Old Dec 29, 2005 | 11:15 AM
silky16v's Avatar
silky16v
Get on That!
you get 3 bar, 4x803, MSD stage 3 closed loop Chip
if the car is already fitted with a lambda sensor it using the excisting wiring if not you would be required to fit your own and it comes with full instructions on how do this
Old Dec 30, 2005 | 02:33 PM
I8A4RE's Avatar
I8A4RE
Hi
Is the chip mapped to run with a t3 or a t34?
Tommy
Old Jan 2, 2006 | 10:04 AM
silky16v's Avatar
silky16v
Get on That!
hi the chip is designed to run with a t34
Old Jan 3, 2006 | 04:37 PM
cosworth87's Avatar
cosworth87
what does a closed loop do?
Old Jan 4, 2006 | 10:38 AM
silky16v's Avatar
silky16v
Get on That!
it uses lambda control when under normal driving
eg: under 4psi of boost, under 4000rpm, and under 35% throttle postion
thus then will return a better fuel economy
Old Jan 13, 2006 | 09:41 AM
Stu @ M Developments's Avatar
PassionFords Creator
I can vouch for this kit, its virtually new.
Old Jan 13, 2006 | 04:28 PM
silky16v's Avatar
silky16v
Get on That!
Cheers STU
Gonna make it open to offers
MSD fitting instruction included and original receipt which helps if u ever need to sell it back on
Old Jan 16, 2006 | 11:34 AM
silky16v's Avatar
silky16v
Get on That!
bump
Old Jan 20, 2006 | 08:39 AM
silky16v's Avatar
silky16v
Get on That!
Kit now Sold
JK12
33
Apr 26, 2021 12:09 PM
timsrs
Nov 13, 2018 11:48 AM
A.t.p
Sep 29, 2015 05:04 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
tib2220
Sep 14, 2015 12:33 PM
