changing photo size for quick uploads.HOW??
Old Dec 26, 2005 | 08:44 PM
twitchyrear's Avatar
twitchyrear
Default changing photo size for quick uploads.HOW??
ive downloaded some images off my digital camera but each one is 14.2mb so takes AGES to upload onto photobucket,how do i get them down to say 2 or 3mb or less??cheers peeps
Old Dec 26, 2005 | 08:47 PM
Stu.H's Avatar
Stu.H
open microsoft paint
load file in
press "CTRL-W"
reduce horizontal to 50% say and same vertical
save file
job done.
Old Dec 26, 2005 | 08:51 PM
twitchyrear
got to do that to all 40??
Old Dec 26, 2005 | 10:40 PM
Redkop's Avatar
Redkop
Use http://bluefive.pair.com/pixresizer.htm - dead easy to reduce multiple images.
Old Dec 26, 2005 | 10:55 PM
Thrush's Avatar
Thrush
Irritating c........
This is the EASIEST picture resizer you can use if you are on XP - works for singles and multiple uploads;
Originally Posted by Thrush
Are you running Windows XP?
If so this is EASY to do!
Download this XP "Power Toy" plug in from the Microsoft site;
Direct download link - save to PC and then install;
http://download.microsoft.com/downlo...ertoySetup.exe
It is a plugin, so once installed you don't have to do anything or open any programmes to use it. You simply right click on the picture you want to resize and in the drop menu there is a new entry called RESIZE PICTURES;
You can also use it for batch converting. Highlight all the pics you want to resize so they are all blue, then right click on one of them and select resize - choose the 640x480 setting and all the pics will be resized to that size, given the same name as the originals with " (small) " in the title.
Under the advanced tab you can select to RESIZE THE ORIGINAL PICTURES (DON'T MAKE COPIES) so you don't double up - tho this will erase the originals and replace them with smaller pics and there's no undo for this, so it's best to resize and keep the originals then copy the resized ones to the memory card.
Old Dec 26, 2005 | 11:01 PM
nolag's Avatar
nolag
cheers thrush,thats what i need.ill download that now
Old Dec 26, 2005 | 11:16 PM
twitchyrear
nice 1 thrush ill have a go at that tomorrow
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
s1turboman
Aug 29, 2015 04:27 PM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
