Turbo Surge
Old Jul 15, 2004 | 07:49 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Default Turbo Surge
Was just reading Spadge's post about his surging turbo and whether or not to enter totb3.
Well for us people (like me) who dont know what surging is can we have a technical response as to what it is and what causes it etc.
CheeRS
Rich
Old Jul 15, 2004 | 07:56 AM
Karl's Avatar
Karl
Norris Motorsport
LOL It's too early in the morning to be bothered.
Old Jul 15, 2004 | 07:59 AM
CossieRich's Avatar
CossieRich
yum. Piss off
Karl: when u can be bothered can u reply. ta
Old Jul 15, 2004 | 08:15 AM
GARETH T's Avatar
GARETH T
its when the turbo is producing too much for for the engine to consume
Old Jul 15, 2004 | 08:30 AM
foreigneRS's Avatar
foreigneRS
Testing the future
there is a post somewhere on here already discussing it in great detail. use the search function and type in turbo AND surge and you should find it.
basically, gareth t is, of course, as usual, correct.
Old Jul 15, 2004 | 09:19 AM
Ima-Racing500's Avatar
Ima-Racing500
You also normally get surge when the boost comes in.....ie on a T4 4000rpm and goes onto around 5000rpm....then it can clear.You will also find it only does it from 3rd gear onwards..4th if your lucky
Old Jul 15, 2004 | 09:39 AM
Stu @ M Developments's Avatar
PassionFords Creator
https://passionford.com/forum/viewtopic.php?t=34511
Old Jul 15, 2004 | 09:44 AM
DazC's Avatar
DazC
On the MD240R it comes on boost at something like 2800rpm and surges up till about 4200rpm and the boost is capped at something like 14 psi then the air to air just wind it up to 35psi and hold it at 30 something or other...
Stu might be able to remember all the specifics or something cos I can't!!
I could be a politician or a solicitor with that reply!
Old Jul 15, 2004 | 09:50 AM
CossieRich's Avatar
CossieRich
Cheers stu. that made some good reading. had to read it a few times but understand it now.
BRAM
Sep 8, 2015 07:11 AM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
