I-Pod incar adapter thing
Need some advice on I-Pods before i buy.
Basically i will be using it mainly for listening to in the car.
I have heard that you can get something that your i-pod fits into and basically makes it like a radio broadcast...IE, you then tune your car radio into for instance 97fm and it picks up your i-pod...............Is this right?
OR
Is there any other way of doing it without using a shit Tape coverter thing
OR
ive been looking into this tiff as i got a pod for xmas
there called i trips
or..............
if you have a pioneer stereo you can get a proper adapter that uses the ip bus connection which then plugs into the pod for much better sound quality
hope this helps
matt
or..............
hope this helps
matt
tiff go on fleebay and search for pioneer ipod
it uses the port that a cd changer uses ( will have to unplug mine)
there about 50 quid delivered i think
i also think you can control the pod thru the head unit but not 100% sure on that
also not too sure if that support the 5th gen ipods yet but they should do
matt
matt
OR
OR
J
Tiff just got one of those cables which just plug straight into the disc changer port for my Kenwood and they're spot on, ditched my disc changer now
the FM transmitters are shite really
edited, just looked on ebay and the cable alone is Ł26!!
mine was only a tenner
Thinking about buying this, looks pretty good and charges to.
http://cgi.ebay.co.uk/iPod-Car-Kit-D...QQcmdZViewItem
to give you an idea Mark.
We do all sorts.
Cassette slot ones.
FM modulator ones
FM modulator with charging points
Ipod links that go in place of CD changers and allow you to utilise CD changer functions on your stereo
Also next month we are doing the one which has a console mounter button and a screen on it
Have a butchers on google for Dension the majority of stuff that they do on there we can supply (its sale this month LOL) if you dont see anything you fancy or theres somet cheaper else where I know where you can get it fitted.
We do all sorts.
Cassette slot ones.
FM modulator ones
I got a FM modulator off my mate today
Like this
http://cgi.ebay.co.uk/ws/eBayISAPI.d..._BIN_Stores_IT
Like this
I just ordered a 60 gig iPod in black and a Kenwood interface for the car!
You can control the Ipod through the head unit so you can bury it in the glovebox and for get about it, apparently.
You can control the Ipod through the head unit so you can bury it in the glovebox and for get about it, apparently.From what I know these come with a cable that plugs into the IPOD and you're supposed to run the cable through to the glove box or where ever to do just that.
Exactly what I want!
I already have an MP3 hard drive in the van instead of a disc changer. Just want this for the car and I'm sorted. Disc changers will probably be a thing of the past eventually.
same sort of thing for the pioneer daz
theres a few of them on fleebay but just want to know if they come with all cables needed etc
then i can sod the 6 disc changer and the mp3 headunit off and put the ipod in the clove box same as you said
matt
theres a few of them on fleebay but just want to know if they come with all cables needed etcthen i can sod the 6 disc changer and the mp3 headunit off and put the ipod in the clove box same as you said
matt
Tiff the cable I got plugs into the changer port and plays the iPOD through the head unit, like I said only cost me a tenner
I'm not too fussed about controlling the iPOD via the head unit, I take it out all the time to update it and use it at work as well (plus I couldn't afford it lol)
http://cgi.ebay.co.uk/Kenwood-Auxili...QQcmdZViewItem
Mark_
40
Oct 2, 2015 04:40 PM
