Fitting poly bushes to S1 (pic)
Old Dec 25, 2005 | 02:03 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Default Fitting poly bushes to S1 (pic)
Anything i need to know before i tear into it? cheers.
Old Dec 25, 2005 | 02:21 AM
NUTS RuS's Avatar
NUTS RuS
Put your coat on - its cold out there
Old Dec 25, 2005 | 02:28 AM
thebigyin's Avatar
thebigyin
simple job m8
Old Dec 25, 2005 | 09:58 AM
AJC's Avatar
AJC
if they are deflex bushes, prep yourself for a long day
Old Dec 25, 2005 | 10:19 AM
vroooom ptssssh
It Wasnt Me!
cheers lads,
Series1AJC, they are powerflex
Old Dec 25, 2005 | 10:28 AM
AJC's Avatar
AJC
vroooom ptssssh
well i hope they fit better than deflex
Old Dec 25, 2005 | 11:25 AM
DazC's Avatar
DazC
Powerflex fit spot on!
Old Dec 25, 2005 | 12:16 PM
vroooom ptssssh
It Wasnt Me!
Any idea if all the nuts bolts and washers are still available from ford new, or are their any stainless steel ones anyone sells? and how much? just for the complete rear end suspension set up justnow!
Old Dec 25, 2005 | 12:25 PM
NUTS RuS's Avatar
NUTS RuS
You DO NOT want to fit stainless steel bolts on any load bearing components David.
Old Dec 25, 2005 | 02:52 PM
vroooom ptssssh
It Wasnt Me!
ok, thanks! just aswell i didnt try that
So will ford be able to get me every nut, washer and bolt for rear susp ?
Old Dec 25, 2005 | 03:23 PM
NUTS RuS's Avatar
NUTS RuS
I think the long one that goes through the stub axle and outer wishbone is NLA from Fords.
We have plenty new ones in stock tho'. The others are just standard sized high tensile metric bolts and obviously all the new nyloc nuts and washers etc available from any hardware shop.
Old Dec 25, 2005 | 03:33 PM
BillyCabrio's Avatar
BillyCabrio
I got quite a few bits from this fella when i was resto'in the cabbie..........
http://search.ebay.co.uk/_W0QQfgtpZ1...QsassZhatchmk3
Some bits are avaliable from Fords still, always worth checking
Old Dec 25, 2005 | 05:11 PM
vroooom ptssssh
It Wasnt Me!
Cheers fella's, they rear roll bar clamps, are they easily broken when changing the bushes over?
Old Dec 25, 2005 | 05:14 PM
NUTS RuS's Avatar
NUTS RuS
Nope
Old Dec 25, 2005 | 06:08 PM
vroooom ptssssh
It Wasnt Me!
cheers Tony, great help
Old Dec 25, 2005 | 09:51 PM
vroooom ptssssh
It Wasnt Me!
Which bush goes where?
I thought i knew but im unsure, just so i know what to take off etc before i start.
Also are the bottom right ones missing an insert as every other set of bushes (set of 4) has 2 each.
Sorry bout pic size but it's just so you can get a closer look.
(im bored )
Old Dec 25, 2005 | 10:16 PM
DazC's Avatar
DazC
Useless tosser!
Old Dec 25, 2005 | 10:20 PM
vroooom ptssssh
It Wasnt Me!
blah blah
Old Dec 25, 2005 | 10:27 PM
DazC's Avatar
DazC
Above the 12mm ARB bushes is the front ARB bushes,
Below them look like the rear tie rod to stub axle bushes,
Opposite the 12mm ARB bushes is the rear wishbone outer bushes x 4,
Above them looks like either the front tie rod to TCA bushes OR the tear tie rod bushes (at the chassis),
Above them looks like the inner TCA bushes.
Doesn't look like you have a full set of bushes there.
Old Dec 25, 2005 | 10:38 PM
vroooom ptssssh
It Wasnt Me!
No it's not a full set but pretty much.
missing I think 4 top mounts, bump stops and rear spring mounts!?
Cant complain at all, Russell done me the good favour of giving me them
front track control arms are new, worth changing they bushes?
am i right in saying their are 2 poly bushes available for the steering rack mounts?
Thanks for your help Darren
Old Dec 25, 2005 | 10:39 PM
mrviper's Avatar
mrviper
dont forget that one of the nuts on the end of the roll bar has a left hand thread
drivers side i think
Old Dec 25, 2005 | 10:42 PM
DazC's Avatar
DazC
Originally Posted by mrviper
dont forget that one of the bushes on the end of the roll bar has a left hand thread
Mine are both normal right handed threads...
Old Dec 25, 2005 | 10:44 PM
mrviper's Avatar
mrviper
humm i did my s2 and one was left hand thread
Old Dec 25, 2005 | 10:45 PM
vroooom ptssssh
It Wasnt Me!
mrviper, Aye i did notice that on the powerflex website, cheers
DazC, taken from http://www.powerflex.co.uk/products....3&submit1.y=19
It sais "SERIES ONE RS TURBO HAS RIGHT HAND THREADED NUT FITTED TO BOTH ENDS OF ANTI ROLL BAR - ALL OTHER RS TURBOS AND ALL MK3 AND MK4 ESCORTS HAVE LEFT HAND THREADED NUT ON RIGHT HAND SI"
Old Dec 25, 2005 | 10:46 PM
DazC's Avatar
DazC
S2 might be. My old Orion 1.6 i Ghia was a left and a right handed thread on the ARB.
S1 have a seperate 2 tir rods and an ARB unlike the S2.
Old Dec 25, 2005 | 10:47 PM
DazC's Avatar
DazC
Yes Dave!
Old Dec 26, 2005 | 09:30 PM
vroooom ptssssh
It Wasnt Me!
What are they long bushes? (not mine, they are deflex app)
and is mine missing a steel insert in the first pic?
Old Dec 27, 2005 | 08:04 AM
ballin's Avatar
ballin
those 2 long ones are steering column bushes!
Old Dec 27, 2005 | 11:58 AM
DazC's Avatar
DazC
David, yes you do appear to have a steel sleeve missing from your picture!
Wilsfoci
15
Mar 30, 2016 10:26 PM
155lee
Aug 14, 2015 11:21 AM
track.focus'd
Aug 12, 2015 05:53 PM
cameron2
Aug 10, 2015 12:14 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
