grey or not
i heard in France that it's very dangerous for the motor to use grey on cossie, because you will be too rich at low rpm, so the fuel wash the cylinder and damage the block
and also, they said that it's a not a good idea for road use
what do you thing about that
bollocks, basically [/Dave mode]
[Not Dave mode] Its called borewash, but most tuners can supply software that control decent levels of fuel low down in the rev range [/ Not Dave mode]
PassionFords Creator
Greys are tiny by todays standards, we now do injectors twice the size that will run teh same emissions yours do now, namely, 0.3% at idle, cruising everywhere at around 15:1 with no problem at all. In fact, ive got my own car running well at 16:1 at the moment.
There is a topic somewhere that may help to explain what you need, i will look for it and BTTT it for you.
