Estimated Top speed for.....
Originally Posted by Tony Turbo
What's it rev to?
The question you MEANT to ask is, where is peak power and how much does it tail off by before the limiter?
Originally Posted by Benn 304R
looks more like approx 440bhp than 450bhp
.I would expect it to hit a true 170mph with wing on.
I would also be VERY careful about doing this speed before having the car det checked. Mark had to pull several degrees of timing out of Yum's car at the top end for top speed runs....
His a bit slow today I think as his normally right on it
Originally Posted by aduz
mike out of interest what did urs pull on the dyno?
good point bill.. you C*NT
I see... Just because i dont even remember my dyno figures because im that bothered about them and have to search the vast archives of pictoral stich ups of members off here, on photobucket... you hound me like a wounded fox at a hunt! c--unt!
Id want my car to be mapped to be safe at top speed from the start
You would be the first to jump on me if it was the other way round you c*nt
Im going back to work now, so will look forward to the barrage of pics and piss takes aimed at me
go on.. f*ck off you big overgrown poof!
Dave, dont forget in comparing your top speed to YUM.......your front bumper has HUGE flat(ish) frontal area, and also the extra drag of the WRC rear wing..........I.E. more drag and higher downforce than the normal Es Cossie shape.
IIRC the WRC Es Cos bodywork was developed with a top speed of approx 125 MPH in mind.
I had 169 out my stage 3 light blues 340 bhp and spoiler.But there was this mad vibrating noise comming from the back of the car i thought at the time it was the spoiler a bit like having your sunroof open and holding the wind flap down makes that mad noise tho the car.
this was on gps not speedo lol
No its mapped on the Dyno in IDEAL / controlled circumstances..
The dyon is ideal for replicating the same RPM position time and time again... EXACTLY to the point... unlike in a car trying to hold it in a certain position
The engine MAY need a slight detune in the car if it is less efficient (cooling etc)
e.g I asked for a safe strong reliable 350BHP engine, so I can turn up at any rolling road and KNOW it will pull 350-360HP
ON the Dyno she managed 375.. so once in the car knock off 10-20 HP (dpending on car etc )...
woohoo Doug, great news!
as long as it does 160, im not bothered!
Ive had a speedo 150 from it in -running in- mode (12 psi) pmsl - Tom tom matched it by 2 mph ( 152)
so double the boost and a bit more should see me to 170
hopefully!
Googlepong ----->
Ive had a speedo 150 from it in -running in- mode (12 psi) pmsl - Tom tom matched it by 2 mph ( 152)so double the boost and a bit more should see me to 170
hopefully!
Googlepong ----->
Ive had a speedo 150 from it in -running in- mode (12 psi) pmsl - Tom tom matched it by 2 mph ( 152):
438
