NEED PICS OF THIS PEDAL BOX FITTED IN A MK2 ESCORT
Old Dec 21, 2005 | 10:39 AM
M K's Avatar
M K
Default NEED PICS OF THIS PEDAL BOX FITTED IN A MK2 ESCORT
need some proper pics of this box fitted in a mk2 esort please as i want to see the angle it actually sits at and how high from the floor to see if it could be made to fit my fiesta xr2
cheers
marc
Old Dec 21, 2005 | 12:07 PM
andyescos's Avatar
andyescos
on an xr2 you've gotta lose most of ya dials or move em as it sits right up in the dash, u can however sit the cylinders where the servo used to be.
Old Dec 21, 2005 | 12:59 PM
M K's Avatar
M K
ive seen the universal box that sits on the old servo bracket,,,
but that stil uses the rod across the bulkhead which gives loads of flex,
Old Dec 21, 2005 | 01:35 PM
andyescos's Avatar
andyescos
yep, that's a shame, junk the dials, fit a tiny rev counter and hey presto!
Old Dec 21, 2005 | 01:50 PM
M K's Avatar
M K
im not using the original clocks anyway mate,,,,,
will be using spa rev counter /speedo ect an gauges mounted on roll cage,,,,,,
does the mk2 escort use a similar clutch ratchet to escort/fiesta or is it all different?
cheers
marc
Old Dec 21, 2005 | 01:55 PM
Dirty Harry's Avatar
Dirty Harry
Super Moderator
I used to run one of these in my fiesta RWD rally car,it will fit but you have to strengthen the bulk head as its onny single skin the top bolts are a bit more difficult to use I cut and shaped some 1inch box section to bridge the gap and welded a captrive nut inside so to bolt it all up secure,I do have photos of the entire build but thay would need scanning
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Gary @ RS CLASSICS
11
Sep 10, 2015 06:49 AM
matman
Sep 9, 2015 05:45 PM
track.focus'd
Aug 12, 2015 05:53 PM
