fitting a quad lnb on a sky dish!!!!!!
i have a quad lnb (universal) to fit on my sky dish. do i take the whole single one off including the bracket which slides into the arm and replace it with the new one and drill a hole in the arm so i can get a screw through it to hold it in place?
any help appreciated
This may sound like a silly question but......... why on earth would you change the LNB on a Sky dish? The system doesn't require anything more than a basic reciever and is only licenced to transmit a one-way signal.
What advantage will you see by changing it?
(genuinely interested btw incase I come across sarcy). I actually used to work for Hughes Network Systems who designed and produced the Sky Satelitte system - and subsequently I now have lots of useless knowledge on Satelittes and LNB's.
One dish and 1 lnb = 1 channel can be watched at any time
Quad lnb = upto 4 digiboxes off 1 dish
All 4 can watch 4 different channels at the same time
Sky do "legit" clone card at Ł10.00 per month
Cloned against the package you subscribe to
http://existing.sky.com/multiroom.asp
Ahhhhhh I see, makes sense actually, I did wonder when they started advertising about the different channels in different rooms package, just how they would achieve that (was launched after I left Hughes).
Now I know, ta
Now I know, ta
Clare, dual lnb required for sky+, quad required for sky+ + multiroom
its a universal one. did yours look like this..
http://cgi.ebay.co.uk/Wistron-Quad-L...QQcmdZViewItem
It is fitted to a Sky Mini Dish
Not bad for a mobile cam pic at 8x magnification - lol lol
track.focus'd
Aug 12, 2015 05:53 PM
