twin headlight conversion on saf question
as title
when you fitted your morrettes what does your in cr display say after fitting them
mine is telling me i have a light out at the drivers front now
i know theres 1 wire not being used in the morrette conversion so is this the display wire
but it also intermitent as sometimes it shows sometimes it doesnt
is this wire to do with it?
all lights work as they should as well even when the display is reading theres a bulb out
any help please
any help please
The warning light on the dash is done by resistance. I fitted some ice white l.e.d. sidelights, amd now its on even though the lights work.
Cant remember what the extra wire does, but the warning light should still function normally with Morettes fitted.
ok then
now the display is on when i turn my lights out
but noticed that when i fit full beam it goes off
also say when igntion off and u turn the lights off its only the passenger sidelight that lights up until you turn ignition on
is this right also
sorry for the questions but its really bugging me whats wrong but carnt find anything
is this right also
chowfornow
14
Jan 5, 2019 09:01 PM
SMILER258
Sep 28, 2015 09:04 AM
