How much for a new loom (ballpark figure)
how much am i looking at to get a new loom for my cossie, 2wd BTW. i think i have some problems with mine and would like a nice fresh new one rather than spending time trying to fix a 15yr old loom.
Thanks
Thanks
Yeah just remebered Ryan does wiring looms
dingy does them too doesn't he??
how many looms are there on a cossie??? bear in mind that i know very little bout wiring, but the ECU loom covers injectors, ign amp, phase sensor, ECT, ACT , CPS , ISCV and probably a few others i've missed, but does it include the wiring to the coil??? i fitted my GrpA coil on friday and noticed the copper wire on the green power wire was black quite a way through
what else does that loom cover?? obviously not lights etc but is there anything major ???
the engine management loom will do it all,,, that what ryan supplys
the loom for the lights ect are a different loom
look under the batt on the bulk head and theres the gromet, then foll the wiring to the plug under the dash near the ECU
you just unplug that will all relays ect attached and then fit in ryans loom on that plug
Ive got one of Ryans and I can confirm they are the nuts.
Incredibly neat and I had a few custom bits put in for ALS, Water Inj, Coil Pack, monitor and ignition amps inside car.
Just perfect and a good price.
JK12
33
Apr 26, 2021 12:09 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
155lee
Oct 24, 2015 11:11 AM
muz
Sep 30, 2015 08:29 AM
