Bolts loose and 1 missing on turbo/housing ! ?
Old Dec 18, 2005 | 11:07 AM
rabmc's Avatar
rabmc
Default Bolts loose and 1 missing on turbo/housing ! ?
Basically last week i heard something rattling from my engine ( as if something was loose ) anyways as it was dark and could not see that well it turned out to me that the the turbo damper was loose , because when i put my hand on top it stopped the noise
Soo the next day and up until now it never mde that noise again and never thought nothing else of it
So last night , went under for a look to check oil and water and all that and noticed that one of my bolts were missing where the housing bolts on to the turbo ( 4,17 mm bolts ) should these be threaded or a bolt and a nut ? and 2 were loose , so tightened up and still need another bolt and nut to get it back the way it was Not a big deal really but why would these come loose guys ? and would i be losing power from this ? and would it do any damage at all troops ?
Had to get that off my chest lol its the first problem in a while lol but defo not the last ehh
Old Dec 18, 2005 | 11:12 AM
JamesH's Avatar
JamesH
If you're talking about what i think you are, this happened to me a while back, it had just stripped 2 of the bolts. Still available from Ford, they are about 1/4 threaded, then just straight rod for another 1/4 of it, then the other half is threaded again IIRC.
Old Dec 18, 2005 | 11:13 AM
Ginge !'s Avatar
Ginge !
just finding my feet
if theres a air leak caused by it ( and prob will have) then YES you would loose power aswell as boost
could explain the 20psi you got, when its all done then check the boost again to be sure
Old Dec 18, 2005 | 11:15 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
In the end you will snap the studs in the head and be in a whole world of shit...
Make sure all parts are to correct torque settings and the damper is adjusted correctly..
How many mounts do you have on the zorst system?
rabmc's Avatar
rabmc
Well the one that i took out was threaded all the way mate Is it ok to use a normal bolt " off a mate " lol do get this tightened back up
Old Dec 18, 2005 | 11:16 AM
rabmc's Avatar
rabmc
Not sure matey its 3.5 inch mongoose to 4 inch tail
How many should there be and iL have a look
Old Dec 18, 2005 | 11:19 AM
Versus_Creations
Ask me a question!
The more the better..
The reason i ask is because if you dont have enough mounts the Zorst will rock on the engine causing the problem you have.
Ginge !'s Avatar
Ginge !
rab have a look where the midle box was removed, its still needs to hae the 2 mounts on that section to hold it up , some places dont do this though
JANO !!!!
i need some helicoils for a head thats got a few threads stripped as where on the same subject
PM me a price please as i know you can get all sorts of stuff
Old Dec 18, 2005 | 11:23 AM
Versus_Creations
Ask me a question!
YB head? or CVH?
If its a YB head and the cam cap retaining threads are threaded then replace with CVH rocker arm studs and countersink the cap.
If its a CVH head what part is threaded as there is many good fixes for these..
rabmc's Avatar
rabmc
JANO !!!!
Top stuff as usual boys , cheers
Old Dec 18, 2005 | 11:26 AM
Ginge !'s Avatar
Ginge !
jano its the zorst studs on a yb head, its got 3 stud where the threads are fooked
top hint about the cam caps though
Old Dec 18, 2005 | 11:28 AM
Versus_Creations
Ask me a question!
Rocker studs again from a CVH
Lager thread size with the same size retaining nuts
Old Dec 18, 2005 | 11:29 AM
Mongoose dont do a 3.5" only a 3". Mines custom 3.5" for 700+bhp.
Old Dec 18, 2005 | 11:34 AM
Ginge !'s Avatar
Ginge !
what manifold studs for a cossie can be sorted with cvh rocker studs
ive got like 4 cvh heads lying about too
muchos appriciate
your a fooking star mate , you could have sold me some "secret" studs to fix it to earn megga cash too
seriously thanks
Old Dec 18, 2005 | 11:39 AM
Versus_Creations
Ask me a question!
I can if you would rather "the special ones"
Old Dec 18, 2005 | 11:40 AM
Ginge !'s Avatar
Ginge !
you know what i mean though
cheers again
Old Dec 18, 2005 | 04:35 PM
rabmc's Avatar
rabmc
Yes 3inch
gambo08
Feb 4, 2016 10:49 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Fil
Sep 30, 2015 12:08 PM
DavidK
Sep 27, 2015 02:55 PM
little bram
Sep 27, 2015 07:45 AM
