Wobble through steering wheel......?
Old Dec 17, 2005 | 05:23 PM
RST_mark's Avatar
RST_mark
Default Wobble through steering wheel......?
I've got a 1990 S2 and when i get to about 65mph i get a wobble coming through the steering column and wheel.
The wheels are balanced and the steering rack and track rod ends in good condition.
I've think i remember reading somewhere that there it a plastic bush somewhere on the steering column that wears and can cause this wobble, is this true?
Any help or advice would be greatly appreciated as i like to get it sorted before i start using the car again.
Cheers, Mark
Old Dec 17, 2005 | 05:53 PM
Matt_B's Avatar
Matt_B
Default Re: Wobble through steering wheel......?
Cheers, Mark
I have exactely the same problem, there is apparently 2 parts you need to replace, tolerance ring part number 6147076 and the bearing 6147075
Gonna get mine soon and see if it works
Old Dec 17, 2005 | 07:06 PM
RST_mark's Avatar
RST_mark
Cheers for that mate, will have to see about getting those bits and give it a go.
Anybody else got ant info on this subject or how you go about fitting these parts?
Old Dec 19, 2005 | 08:43 PM
SafeChav's Avatar
SafeChav
Check your discs for warps...........common problem to the MK3/MK4 Escort/Orion.
When doing this speed with the vibration if you brake does the steering wheel wobble/shake even more? (its quite scary if it does)
Old Dec 19, 2005 | 09:46 PM
T28 RST's Avatar
T28 RST
Ok then
I had the same problem and AVA had the answer, they asked me if i had the wee plastic spiggot rings on the wheels, so they would sit centre on the hub, i didnt
Spent £10 on 4 of theses and it totally transformed the car, no shakes or vibrations now
Old Dec 19, 2005 | 10:01 PM
RST_mark's Avatar
RST_mark
Yeah the discs and pads are in goon condition, not that old since converted to cossie spec.
The wheels dont require the plastic spigot ring that you are talking about because they are a direct fit onto the hub.
My suspicions are with the plastic bush/bearing on the steering column.
Thanks for your advice anyway, very much appreciated. Anybody else got any ideas?
Old Dec 20, 2005 | 05:23 PM
olliehampton's Avatar
olliehampton
i have the same problem does the dash sound like its about to shake its way out of the car. As you can tell mine is bad.
Old Dec 20, 2005 | 05:27 PM
olliehampton
where can i get the rings from t28 rst??. sounds like that is my problem.
Old Dec 21, 2005 | 09:47 AM
RST_mark's Avatar
RST_mark
Think i'm gonna have to speak to ford to see what bushes there are to replace on the steering column and order them up.
Old Dec 21, 2005 | 04:25 PM
Mr.h.'s Avatar
Mr.h.
This might help you mate?
I did have a KEy but i cant find it on my hardrive
Nick
Old Dec 21, 2005 | 05:04 PM
T28 RST's Avatar
T28 RST
Ok then
I got them from the local alloy wheel shop
Old Dec 21, 2005 | 06:54 PM
RST_mark's Avatar
RST_mark
Cheers mr h, now any idea which parts it is that i will need to replace because it's not very clear from the diagram. Have you done it on yours? If so how hard was it to do?
Old Dec 21, 2005 | 10:13 PM
Mr.h.'s Avatar
Mr.h.
I replaced 6and 8 from the diagram! There plastic bearings!
Its a bit fiddly but not to bad!
Nick
Old Dec 22, 2005 | 06:34 AM
filthyrichie's Avatar
filthyrichie
might i suggest rotating tyres front to rear and re test driving .....alot of shakes come from tyres wearing badly that although are balanced you cant see there at fault
we cure alot of cars with this simple test
Old Dec 22, 2005 | 09:51 AM
RST_mark's Avatar
RST_mark
I might give that a try before i go changing the plastic bushes, although it hasn't been long since i fitted the tyres and balanced them. Worth a go though or trying the wheels off my other escort as i have no problems with that.
tankybaby66
Feb 6, 2016 02:24 PM
IainRS1700T
Sep 25, 2015 06:44 AM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
