Newbie - Few Issues
Old Dec 17, 2005 | 02:14 AM
Steve__H's Avatar
Steve__H
Default Newbie - Few Issues
Hi All,
Just Picked Up A MK5 Escort With A Series II Rs Turbo Lump, And Have A Few Questions.
1)Someone Has Fitted A Bleed Valve And The Boost Guage Spins Round To About 2.0 Bar When Accelerating. (The Engines Standard By The Way)
2)Is It Common For The CVH Turbo Engine To Keep Spitting Spark Plugs Out? No.3 Keeps Coming Out For Some Reason. Threads Good In The Head And Tightened The Plugs To The Correct Torque.
3)Another One Of Its Party Tricks Is Blowing Its Oil Cap Off Common ?
Steve
Old Dec 17, 2005 | 03:53 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Dont sound like a good engine at all And will probably need a rebuild
Running to much boost for the engine...Also im guessing that it has a standard intercooler aswell
As for the reasons...
1, The bleed valve is more than likely open all the way , so the engine is running to much boost ( like you say )
2, can only think this is a compression problem
3, Could be a number of reasons... Oil breathing / water not circulating
Not to sure to be honset.. but either way, its not looking god...
Old Dec 17, 2005 | 07:28 AM
adamS2RST's Avatar
adamS2RST
Take it to a tuner ASAP!
Old Dec 17, 2005 | 09:07 AM
ballin's Avatar
ballin
fuckin ell, ~30psi std engine? pmsl bye bye (bet it shifts!! altho i reckon gauge must be dodgy, isnt a TIM is it?)
sounds to me your lucky its throwing the sparkplug out rather than a rod if its accurate!!
but theres something cronically wrong with it mate, needs looking at and as rad says reckon the engine is fubared
Old Dec 17, 2005 | 09:09 AM
Steve__H's Avatar
Steve__H
One Problem I've Just Found, The Cooling Fan Blows Air Away From The Rad Instead Of Sucking It Through
Quality Motor This One, Good Job Its Only My Project
Old Dec 17, 2005 | 02:44 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
2bar will blow your engine, turn the bleed vale right the way in.
are they correct plugs? sounds too small?
heavy breathing - blocked breather/fucked piston rings
Old Dec 17, 2005 | 02:58 PM
Steve__H's Avatar
Steve__H
Its Gone Pop In A Big Way Now
Searching For A Good Standard Engine, If Anyone Has One Kicking About
Old Dec 17, 2005 | 04:31 PM
adamS2RST's Avatar
adamS2RST
Ouch, too late!
Old Dec 17, 2005 | 04:50 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
matter of time
Old Dec 17, 2005 | 04:55 PM
Steve__H's Avatar
Steve__H
Least I Can Start Afresh Now, Have Searched The Forums, Cant Really Find A Spec Above Standard That Will Maintain Reliability.
I'm Not Looking For Mega Power, Just A Bit Over Standard Really.
Anyone Care To Throw Some Suggestions Into The Mix ?
Old Dec 17, 2005 | 04:57 PM
Oranoco's Avatar
Oranoco
180bhp is a piece of piss on a good engine and should suffer no reliability issues over normal.
Sorry to hear it went pop
Old Dec 17, 2005 | 05:17 PM
EssexMikeSi's Avatar
EssexMikeSi
i was gonna say is the amal valve connected? people sometimes tend to unplug it wen theyve fitted a bleed valve which surely means the cars boost is all over the shop
Old Dec 18, 2005 | 01:48 PM
ballin's Avatar
ballin
sorry to hear it mate, was inevitable tho!
Old Dec 18, 2005 | 03:29 PM
Dan's Avatar
Dan
Think at 2bar it was a case of 'When' not 'If' mate, good luck with finding a new engine
Old Dec 18, 2005 | 05:22 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
was it the stolen recovered mk5b off ebay rs turbo'd?
jess that thing got relisted some times
Old Dec 18, 2005 | 07:50 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
engine in the back of fast ford mag (jan,800 quid,all new bits says!
or a brand new one from ford a grand!
Old Dec 18, 2005 | 10:26 PM
AJC's Avatar
AJC
whilst engine nakered go full hog
and go 230bhp with a rebuild
i dont regret it one bit
Old Dec 20, 2005 | 04:23 PM
ze-vh phil's Avatar
ze-vh phil
you sound suprised its blown up!!!!
were not
Mark_
14
Jan 16, 2016 05:27 PM
SMILER258
Sep 28, 2015 09:04 AM
turbotrev
14
Sep 27, 2015 10:44 AM
pabloXR
Sep 21, 2015 12:42 PM
Rammer46
Sep 18, 2015 08:31 AM
