water pump has gone, buying cambelt and pump, info needed
Old Dec 16, 2005 | 04:10 PM
cuvner's Avatar
cuvner
Default water pump has gone, buying cambelt and pump, info needed
wana do my cam belt at same time, antifreeze has pissed all over it! what do i need to order? belt, pump now should i get a verniar pully and do i need tesioners or is it part of the pulley? the guy at english ford said the tesioner is the pulley, ive got a feeling he is on about a different pulley to me?? Wen he said i would need a pulley, for some silly reason i though he meant the drive pulley for the cam, now thinking about it he probably means a tensioner pulley right??
Old Dec 16, 2005 | 04:17 PM
sufsRS's Avatar
sufsRS
just get a full timing belt kit gates is the best
Old Dec 16, 2005 | 04:22 PM
zippyobrien's Avatar
zippyobrien
the pully above the water pump is the tensioner. this has to be removed before the water pump can come of by the way (i didnt realise and it had me stumped for a while lol)
cuvner's Avatar
cuvner
i asked for one but they had never heard of kit for the cvh only the ztec
Old Dec 16, 2005 | 04:31 PM
sufsRS's Avatar
sufsRS
they are talking complete crap mate go to a motor factors and ask for the complete gates kit
Old Dec 17, 2005 | 11:35 AM
ivorbiggun's Avatar
ivorbiggun
If you've got decent tools/ability the whole lot should take a couple hours.
The trickiest bit is getting the lower belt shroud off so you can get at the
water pump.
However, if you're having trouble indentifing the tensioner/pulley you should
buy a haynes manual immediately and/or get someone else to do it. Good luck.
Old Dec 17, 2005 | 02:41 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
crankshaft bolt - put the ratchet on it from below, hold it! and get someone to turn the ignition key just so it cracks the bolt, little tip to get that off
MARK the cam and crank pulley before you take them off.
replace timing belt, water pump/gasket/tensioner if it's worn, threadlock the bolts! tension the timing belt, it should twist 90 degrees, and if you pull it it should have a nice whip on the belt (you'll see what i mean) turn the engine over via the crank bolt (a few turns of the pulley) to makesure nothing is making contact!
oh and refill with uncle freeze
Old Dec 17, 2005 | 03:39 PM
rswoza's Avatar
rswoza
thats a pretty dangerous piece of advice, just put a spanner on the bolt and tap it with a hammer making sure the car is in gear.
the day befor you do the job lag the bottem pully crankshaft bolt with wd40 getting the bolt out is fine the pully does have a tendancey of sticking onto the shaft.
Old Dec 17, 2005 | 06:54 PM
cuvner's Avatar
cuvner
all done, new belt tensioner, idler and pump
Old Dec 17, 2005 | 07:49 PM
vroooom ptssssh
It Wasnt Me!
rswoza, not really, works well. Only dangerous if you dont disconnect the coil lead and if you do it properly (without holding the ignition on) the starter wont even turn.
Old Dec 19, 2005 | 08:21 PM
SafeChav's Avatar
SafeChav
Fair enough mate if it works for you but i wont be trying that one
Im amazed u can get a ratchet on the end of it aswell............barely enough room for a spanner
cos elle
Sep 1, 2015 06:48 PM
kosienutter
31
Aug 22, 2015 09:55 AM
3doorcozmess
Aug 21, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
