Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
FAO chip & stu(map v rpm and throttle pos)
Old Dec 16, 2005 | 10:10 AM
Jay,'s Avatar
Jay,
Sponsor
Default FAO chip & stu(map v rpm and throttle pos)
okl my dta and a lot of dta users rpm vereses load but gareth enlightened me into map verses rpm ad the dta has compensation map seems not to matter either way u do it
BUT
lol there always is with me what are ur preffered way for the happy medium drivability and power
cheers jay[/quote]
Old Dec 16, 2005 | 10:12 AM
I suspect Stu will say he is completely not bothered wether its RPM vs TPS + map as an adjustment or if its RPM vs map + TPS
The reason being he remaps existing systems all the time so has no choice but to do it the way they do so must have loads of experience of both.
Personally i find rpm vs map easier to get my head around.
Stu of course has to deal with airflow as well on many setups.
Old Dec 16, 2005 | 10:15 AM
Stu @ M Developments's Avatar
PassionFords Creator
Depends what you are counting as "Load" If throttle position then map against manifold pressure instead as its better, or as well if possible.
Old Dec 16, 2005 | 10:16 AM
PS
On older DTA you have no choice as it wont actually do RPM vs MAP anyway!
Old Dec 16, 2005 | 10:17 AM
GARETH T's Avatar
GARETH T
i just dont like the idea of a correction factor for pressure,,, im not saying its wrong,, its jsust i would rather calibrate map sites
Old Dec 16, 2005 | 10:18 AM
me too.
Old Dec 16, 2005 | 10:21 AM
Me three, im actually going to send my DTA off to swap it round as mine is on the older software that wont do rpm vs map at the moment.
Although i have toyed with the idea of an AMM as "load" and trying it that way, just cause that seems to work so well in production cars!
Old Dec 16, 2005 | 10:25 AM
Jay,'s Avatar
Jay,
Sponsor
mmmmmm coz ive bin shown the rpm verses throttle im not to sure about the map v rpm yet
chip ive got a vesion 29 chip if u want it just had mine upt to 35.2
cheers jay
Old Dec 16, 2005 | 10:28 AM
The version numbers dont mean anything to me im afraid mate!
I do know that mine is compatable with the later software though as the guy i bought it off checked with Alan.
Old Dec 16, 2005 | 10:30 AM
Jay,'s Avatar
Jay,
Sponsor
it will say if u live it up or on the cpu let us no ill get it in the post
cheers jay
Old Dec 16, 2005 | 10:36 AM
Ecu is just sat minding its own business on the shelf at the moment, but i will be using it in a couple of months.
Are you saying the chip you have is a direct swap into the ECU and will then accept map vs rpm?
If so, why not use it yourself instead of doing it the load way?
Be a good excuse to map it all over again from scratch
Thanks very much for the offer, MUCH appreciated, and if you dont decide to use it then i would certianly be interested in it
Old Dec 16, 2005 | 10:42 AM
Jay,'s Avatar
Jay,
Sponsor
ok chip v29 witch ive replaced with 35,2 dose it both wats mate there both the same the only diff is u get a idle map on 35.2
cheers jay
Old Dec 16, 2005 | 10:44 AM
Sounds spot on then mate, how much do i owe you?
Old Dec 16, 2005 | 10:46 AM
Jay,'s Avatar
Jay,
Sponsor
nowt pm ur ad and ill get it off to ya just copy the existing map when the ecu is live to the pc change chips then upload it happydays lol
Old Dec 16, 2005 | 10:47 AM
You sir, are a fucking star
Old Dec 16, 2005 | 10:56 AM
Garage19's Avatar
Garage19
Passion Ford at its bestest!
Old Dec 16, 2005 | 11:07 AM
Sketch's Avatar
Sketch
Might be of interest to you Chip if you want the latest version of the DTA eprom - i just e-mailed Allan at DTA at about 3pm on a Friday afternoon a few months back and the new eprom was with me at 11am on the Saturday morning!
2 minutes to get the case apart and swap the eproms and jobs a good'un!
and it didnt cost me a penny
So might be worth doing that to get the very latest version?
Old Dec 16, 2005 | 11:14 AM
Jay,'s Avatar
Jay,
Sponsor
mmmmmmmm cool i payed Ł40.00 for my upgrade . chip its up to u sir
cheers jay
Old Dec 16, 2005 | 11:16 AM
Cheers for the tip Sketch, will bear that in mind if i have any problems with this one Jay is sending me
Old Dec 16, 2005 | 11:24 AM
cheers jay
Still send it if thats cool with you mate, its much appreciated
Old Dec 16, 2005 | 11:34 AM
Jay,'s Avatar
Jay,
Sponsor
on its way
cheers jay
Old Dec 16, 2005 | 11:38 AM
Passionford rules
SO many top people on here
Old Dec 16, 2005 | 11:59 AM
Jay,'s Avatar
Jay,
Sponsor
ok just started seting a map up for preasure v rpm
does this look ok
1=0
2=22
3=44
4=66
5=88
6=110
7=132
8=154
9=176
10=198
11=220
12=244
13=266
14=288
this is a 3bar map sensor
cheers jay
Old Dec 16, 2005 | 12:39 PM
Sketch's Avatar
Sketch
You wont need the first column to be 0 as you'll never see that (i have got 0 as my 1st column at the moment and havent been bothered to change it yet, but if i dont, i'll lose a column of load sites)
i have got similar ish to you... something like 0, 20, 40, 60, 80 100, 125, 150, 175, 200, 225, 250, 275 and 288.
Old Dec 16, 2005 | 01:00 PM
Garage19's Avatar
Garage19
I take it the load figures are in Kpa?
I doubt you will see any less than 30 Kpa, so as sketch said, no need to have load sites under that.
One thing to point out is that your load points don't have to be linear.
You may find that as you carry on mapping it will make more sense to group some load sites out where there are big fueling changes and space some out where the fuelling doesn't change much.
For example the transition between vacum and boost always seems quite a hard point to map, so i bunch a few load points up around 100Kpa to get it spot on. Its all about getting higher resolution at the points where you need it.
You can also do this with the rpm sites.
I would suggest you try and find a dyno sheet of an engine that is similar spec to you and check out where the biggest changes in the torque curve are. Bunch your sites up around these areas beacause this will be where the biggest changes in fuelling are.
You might find that you can map it reasonably ok with linear load points, but it does tend to be harder on turbo engines, big cam engines, or ecus with less resolution eg 12x12 maps rather than 30x30.
Old Dec 16, 2005 | 01:41 PM
As garage 19 says, you probably need to alter them when you see where you need more resolution.
you could probably repalce 0-5 with
80
and quite happily let it interpolate between them, which would free up 2 load sites for where it matters more.
Old Dec 16, 2005 | 01:49 PM
Garage19's Avatar
Garage19
Jay,
Are you going to be running closed loop for idle and cruise?
Old Dec 16, 2005 | 02:08 PM
Good point!
Makes low end resolutions even less important if you are closed loop anyway!
Old Dec 16, 2005 | 02:12 PM
Garage19's Avatar
Garage19
Chip, my point exactly!
Just out of interest, I take it DTA has 14x14 tables?
How good is the mapping software? Someone once mentioned to me that it wasn't very user friendly when mapping it live?
Old Dec 16, 2005 | 02:17 PM
Seems ok to me, not used it much though
I dont live map properly anyway, go for a driver, log everything, come back and adjust.
Im hoping to get some live mapping tuition from stu later on!
Old Dec 16, 2005 | 02:22 PM
Garage19's Avatar
Garage19
In a way, sometimes i think thats the better way to do things. Makes it easier to understand whats going on in your engine.
I tend to live map to a point and then data log and fine tune to get it spot on.
Has DTA got data logging facilities?
Old Dec 16, 2005 | 02:28 PM
I use a wideband that logs:
AFR / Rpm / Boost
You have to tap into the boost and rpm signal though obviously.
I prefer to do it that way cause i can drive it myself then, so if i feel something wrong i can stop.
Also means 10 seconds use is enough for a fair bit of offline mapping, so you dont have to drive an umapped car very much.
Old Dec 16, 2005 | 02:54 PM
Jay,'s Avatar
Jay,
Sponsor
ok first thing first chip, chips posted right the colum i have put up was to see it i understood the principle .
ok right ive got a power graph of the car on webber managment and im only runin 2 psi more boost at the mo so could i use this as a ref?
right i still cant put my map up lol tick as feck
so my rpm load sites are as follows
501
800
1400
1800
2200
2600
ect so my thought was to put more rpm sites in especaily towords the mid and top end then like u have said move the kpa around a little then hopefully get a real smooth light throttle ect then a mean mid/top eend
yes i am goin closed loop for idle and cruze but irtll be switched at a higher rpm
cheers jay
Old Dec 16, 2005 | 02:58 PM
If you have the power curve, any peaks on the torque curve need to be a load point really.
BUT bare in mind that they might have been peaks on the old setup cause of how it was mapped not for any physical reason.
Old Dec 16, 2005 | 03:06 PM
Jay,'s Avatar
Jay,
Sponsor
ok but i can use the graph as a reference point?
also the lc1 gauge ive got has got lm1 contoller so its gona be hard wired in , another thing i need to learn is how to use the log facilities on the dta + the controller so theres guna be sum serious readin over xmas lol
so once ive built my sudam hussain ear muffs ill have everything i need hopefully
cheers jay
Old Dec 16, 2005 | 03:11 PM
Jay,'s Avatar
Jay,
Sponsor
i think it is 14x28 when doin a live map its a little bit of a pratt as u adjust what ur workin on then save it then go back into the screen but once ur use to it it aint bad and also its the first time ive played with standalone so to me its all i no lmao
cheers jay
Old Dec 16, 2005 | 03:14 PM
I would imagine that for live mapping you REALLY want the tuning dials, but not tried them myself.
Mate had a set though and they seemed to work really well.
Old Dec 16, 2005 | 03:15 PM
Jay,'s Avatar
Jay,
Sponsor
yeh i got a dyno box chip
cheers jay
Old Dec 16, 2005 | 03:16 PM
Jay,'s Avatar
Jay,
Sponsor
a link for the dta software
http://www.dtafast.co.uk/index.htm
Old Dec 16, 2005 | 03:19 PM
Did you buy a box or make one?
