actuator rod, shorter for more boost?
Old Jul 13, 2004 | 05:15 PM
rog's Avatar
rog
Default actuator rod, shorter for more boost?
is this correct, if so i have something wrong somewhere.
Cheers!
sf's Avatar
sf
Default Re: actuator rod, shorter for more boost?
Cheers!
yip
Old Jul 13, 2004 | 05:17 PM
rog's Avatar
rog
Fuck.
Old Jul 13, 2004 | 05:21 PM
sf's Avatar
sf
Fuck.
how come, what you done
Old Jul 13, 2004 | 05:31 PM
wimwerf's Avatar
wimwerf
if you shortens your actuator rod you get more boost. because the spring inside the actuator stiffens up.
Old Jul 14, 2004 | 09:26 AM
rog's Avatar
rog
That's what i was thinking, just worried i was having a blonde moment and doing something stupid. Swapped turbos and car is only boosting 10psi now, it was boosting 15psi before, and is supposed to be about 24psi......... Can't find the problem anywhere, changed the amal valve and actuator too, and my hoses seem ok!
Old Jul 14, 2004 | 02:01 PM
wimwerf's Avatar
wimwerf
good luck
Old Jul 15, 2004 | 06:52 AM
CosRush's Avatar
CosRush
Have you rejetted the Amal Valve?
You'll need to in order to get 24psi......
Old Jul 15, 2004 | 10:01 AM
rog's Avatar
rog
Yes i have a GGR amal valve, but i was getting 24 psi before with the old one. Swapped intercoolers and hoses last nite but still no improvement.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
A.t.p
Sep 29, 2015 05:04 PM
Russ Payne
Sep 25, 2015 08:29 PM
