Water leak - HELP!!
Right I have a water leak somewhere in the engine bay but for the life of me I cant find where its coming from. Its dripping down from the gearbox cradel but as there are no water pipes above this area it must be running down from else where..
Anyone else had water dripping from this area??
Its got me stumped!
Dan
Its got me stumped!
Dan
Originally Posted by zippyobrien
could be the rad driping from the bottom corner on to the gear box craddle
cheers
Yes mate I had this on mine and it turned out to be the small hose to the thermostat housing that had split and was spraying water.
Run the car and wiggle all the water pipes and you'll probably get a nice hot jet of water in the face like I did
I have checked around there but cant find anything, will check again when the engines on........ in 2006
by the way dan,
your car is fu**in sweet dude, it just sits right,
especialy with the front splitter and trimmed front bumper. looks very smooth!!!
nice one mate
nice one mate
I had a similar problem for ages and ages on mine....a little bit of water would trickle out from the hole in the gearbox cradle.....
turned out it was a corroded core plug in the block [there is one thats inside the gearbox bell housing
So its gearbox/clutch/flywheel off to change
Check everything else first!!
]So its gearbox/clutch/flywheel off to change
Was going to mention core plug, very annoying they are, had one go on my old MK5 escort, it must have had a hairline crack because it would only leak a small amount but you could see where it had run down the block!
Mark RS
Oct 12, 2015 06:01 AM
