My car and cosworth managment
Guys i want cosworth managment for my car. what will my engine need to survive the conversion ?
right now i got:
7:6:1 Low Compression Mahle Pistons
Mildly ported head
modified fuel system ( for increased fuel pressure when on WOT only )
hybrid T3 turbo
360 degree thrust bearing
48 exhaust housing
60 trim compressor
-31 actuator
Ahmed Bayjoo open chip with revised ignition curve
3 degrees advance
GRS EVO 3 intercooler, two Kenlowe 2000 blow fans
Samco hoses
Scorpion stainless exhaust system
GEARTORQUE £1000 Gearbox
26 Psi Boost
right now i got:
Mildly ported head
hybrid T3 turbo
48 exhaust housing
60 trim compressor
-31 actuator
3 degrees advance
Samco hoses
26 Psi Boost
ive just had it fitted to my turbo not on the road yet so dont no how it drives yet . comes with a new loom quality finish on it, where as with cossie u are using second hand parts mine use 2 be on cossie got ripped out
nick from performance ford is on gotech check out the mag this month
give jamsport a ring on 01604 755529 and get them to put gotech on it 4 u
Aug 14, 2015 07:29 AM
Cameron
14
Aug 9, 2015 06:28 AM
