popin in and out of gear change ???
Old Dec 11, 2005 | 05:20 PM
JayRS2000's Avatar
JayRS2000
Default popin in and out of gear change ???
had my car set up and its making a poping sound like a rally car spitting as it changes gear whats couses this ? overfuelling >?
only when im boosting hard tho.......
i personally love it but dont fink its ment to do it LOL
Old Dec 11, 2005 | 06:29 PM
JayRS2000's Avatar
JayRS2000
any body ? no ? dust ?
LOL????
Old Dec 11, 2005 | 06:31 PM
ballin's Avatar
ballin
aye heavily over-fueling by the sounds of it, whats the spec and who set it up?
Old Dec 11, 2005 | 08:19 PM
Oranoco's Avatar
Oranoco
Mine pops on the over run after a damn good caining. But something sounds a little a miss
Old Dec 11, 2005 | 09:38 PM
zippyobrien's Avatar
zippyobrien
went to look at me new turbo today (im hope fully gunna buy it.) on the test drive, gave it big stick in second, changed gear, pop and a giant flame lol (it hasnt got a flammer) it also seems to do it alot when letting of in 5th. has just been set up by 'the phirm' its runnin 10psi on standard chip. will this constant back fireing damage the car?????
the bloke who mapped it apperently said the fuel may need turning down in a few weeks (said at time of mapping)
Old Dec 12, 2005 | 08:35 AM
ballin's Avatar
ballin
well for a start it hasn't been mapped because you can't map the ke-jet escort so thats bollocks for a start! why would the fuel need turning down in a few weeks, dont get that
doesn't sound good to me, if I were to buy it I'd take it straight to a RS tuner and get it sorted out
Old Dec 12, 2005 | 09:03 AM
antony215's Avatar
antony215
Escort Rs Turbo
as ballin said why would you need to turn the fuel down if the car has just been setup then the tuner should have done fueling so it should be ok i think that guy is telling you porkie's
Old Dec 12, 2005 | 04:00 PM
andre_k's Avatar
andre_k
whose 'the phirm'?
if i was you id tell 'the phirm' where to go, they obviously dont know qhat theyre talking about...
back to the topic, my s2 has recently been set up by Jamsport, and she gives out the odd pop under hard use when changing gears, normally uphill or with alot of people in the car.
Old Dec 13, 2005 | 04:22 PM
zippyobrien
sorry, incorrect term used. the car hadnt been run for a long time, and had to have a new metering head (ive known the car for ages which is handy)
the phirm (i think thats how its spelt, they deal with alot of bmw i think (some one correct me if im wrong)) fitted the unit and adjusted the fueling to its correct level. he said that after a few weeks it wil start to over fuel and pop and bang in and out of gears changes and will need the fuel pressure turning down slightly.
the car was fine for a few weeks (went out in it the day it was done) before starting to pop and bang......
will probably get it then have the fueling checked..
Old Dec 13, 2005 | 06:46 PM
JayRS2000's Avatar
JayRS2000
my specs
chipped
inductionkit
pace intercooler
running bout 15-16 psi roughly
and ive just had fitted a gasflowed and ported head should help the breathing
being set up 2moro at a local garage.
hopefully ill get a dyno done soon and set up on the rollers
Old Dec 13, 2005 | 10:35 PM
antony215's Avatar
antony215
Escort Rs Turbo
if it's been adjusted right it would'nt need to be done again in a few weeks i think someone's telling you lie's or the "phirm" dont know what they are doing no GOOD tuner would adjust a car to over fuel there would be no point to it unless they are trying to get more money out of you
TPM961
Jan 15, 2018 10:50 AM
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
marky_g
Sep 12, 2015 04:26 PM
Adam Graham
Sep 6, 2015 06:04 AM
