head gasket best one ?
Dec 10, 2005 | 07:38 PM
why is a std headgasket set from ford a gen part was 120squid and when i looked at sum cosmetic headsgaskets and group a ones were less ??
are the ford ones better ?? im planning on running 15-16 psi so would i need a group a one ?
Dec 10, 2005 | 07:43 PM
ford headgasket's are just as good if not better than group a one's
Dec 10, 2005 | 07:45 PM
mate told me that ill go for the std ford jobbie
Dec 10, 2005 | 07:49 PM
they are £30 singularly
bolts are a tenner from motorfactors, i never use ford bolts
Dec 10, 2005 | 07:54 PM
would be best to get the kit tho ???? everything new as im getting a polish and ported head hopefully
Dec 10, 2005 | 07:57 PM
if you doing a top end rebuild then get the set
Dec 10, 2005 | 07:59 PM
will do im hopeing to get this done and fitted and should be sweet as turned my boost down aswell and its stoped pinking so all good
Dec 10, 2005 | 08:01 PM
yeah if ur messin with iot you'll need the lot, a simple h/gasket swap u will just need the gasket, bolts and cambelt while ur there
Dec 10, 2005 | 08:04 PM
already to hand
Dec 10, 2005 | 11:09 PM
What's a Group A headgasket for a CVH?
Ford are THE best, DO NOT buy anything other, even for 300+bhp
Dec 11, 2005 | 08:13 AM
uprated multy layer gasket i think 1.7mm thickness
not sure think so
Dec 11, 2005 | 09:50 PM
good to see you repairing the wagon mate.............
will be great when shes done
Dec 11, 2005 | 11:38 PM
hmm, well forget it. christian and beccy's/tony turbo's 300+bhp rst's run std ford, they'll tell you themselfs not to buy anything else
Dec 12, 2005 | 06:02 AM
Thanks. You saved me the bother of telling people for the 1 millionth time
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
pie-face
Sep 15, 2015 10:43 AM
