MAP sensor question.
Old Dec 9, 2005 | 10:36 PM
pee vee's Avatar
pee vee
Default MAP sensor question.
think my map sensor has had it, as SECS monitor keeps saying
MAP input fail (i know it could be the monitor/connection)
but I have a brand new 3bar sitting here, (see if that cures it)
IS it ok to change the standard 2bar one straight to a 3bar?
or has the managment gotta be messed with?
thanks
Old Dec 9, 2005 | 10:37 PM
GARETH T's Avatar
GARETH T
not safe to change mate
Old Dec 9, 2005 | 10:39 PM
pee vee's Avatar
pee vee
ok thanks mate!
better get the new set up ordered a bit quicker than expected then!!
along with the engine out and freshen up.
too cold out to piss about with it lol
Old Dec 9, 2005 | 10:45 PM
GARETH T's Avatar
GARETH T
buy a run-a-round and leave it till better weather
Old Dec 10, 2005 | 12:19 AM
ECU Monitor Enthusiast
Phil, check the plug on the back of the monitor hasnt fallen out or is part loose !
Old Dec 10, 2005 | 03:26 PM
pee vee's Avatar
pee vee
thanks guys!
Simon, will do!
the problem seems to be OFF throttle. if the car draws more than 14.8psi
VACUM then it says MAP sensor fail..
Old Dec 10, 2005 | 03:48 PM
Sounds like your map sensor is drifting out of range.
I have one here you can have if you want it mate FOC.
(I presume its a standard 2.0 bar map sensor)
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
